Quote Originally Posted by waway View Post
good day po sa lahat.
may inquiry lang po ako regarding hid. yung nabili ko po yung car ko (2nd hand) may dala po siyang hid pero walang low beam, high beam lang meron. ano po ba pwedeng gawin para naman may low beam? change lang po ba ng bulb o change lahat pati ballast? may nakapagsabi sakin na meron po daw ganyang type na hid dati. meron po ba o sira na po itong hid ko?
I think you are referring to the telecopic type of HID bulb, that moves up and down to simulate hi and lo beam, since HID bulbs unlike traditional H4 with dual beam has only a single beam. Though if you really wan't the most effecient way of getting the most out of HID in your headlight you should look into a projetor conversion, traditional lights that use halogen bulb are not optimised for HID so an HID bulb on a halogen light casing may look bright but since it's not focused properly mojority of the produced light are not aimed to where you need it to be (the road), in most cases it is aimed to high that it creates glare for oncoming vehicles and can easily cause an accident since it can blind the oncoming vehicle's driver.
