Results 1 to 10 of 19
- Oct 2014
- 37
December 2nd, 2020 10:10 PM #1Good evening po sa lahat. Pahingi po ako ng tulong. I have a 2017 Honda HRV. Yung fog lights ko po parehong biglang ayaw umandar nung isang araw. Pinacheck ko sabi ok daw ung bulbs so pinalitan ng bagong fuse. Umandar na ung lights. Nung gabi na ginamit ko na siya pero mga 20 min lang biglang ayaw na umandar ulit. Ano po kaya ung pwedeng problema? Naka aftermarket po ako na LED H11 pala na nagamit ko naman for 5 months without a problem tapos ganun po nangyari. Thank you po.
- 54,309
December 2nd, 2020 10:12 PM #2
- Oct 2014
- 37
December 2nd, 2020 10:15 PM #3
- 54,309
December 2nd, 2020 10:18 PM #4ask an expert to look at your set-up, po.
fuse... wiring... housing...
if the (stock, i assume) fuse keeps blowing kasi, your lights are probably drawing more current than what the car's wiring was designed for.
you might have to upgrade everything and not just the fuse.
btw,
i noticed that many car drivers use their bumper lights and not their headlights.
are they aware that sometimes, them bumper lights actually generate more glare than the stock headlights?Last edited by dr. d; December 2nd, 2020 at 10:34 PM.
December 2nd, 2020 10:30 PM #5
- Oct 2014
- 37
December 2nd, 2020 10:40 PM #6
- Oct 2014
- 37
December 2nd, 2020 10:41 PM #7
- 54,309
December 2nd, 2020 10:52 PM #8
- Oct 2014
- 37
December 2nd, 2020 10:53 PM #9
- 54,309
December 2nd, 2020 10:59 PM #10normally,
my suggestion would be to bring it back to them for trouble-shooting.
there is definitely something wrong if your fuse blows twice...
the other side of the coin is,
they may not be fully versed in what they should be fully versed in...
what would i do?
i'll probably feel my wiring and see if they get "too hot", and go from there...
but so many things can be the matter...
you need the experts, if i may opine.
Hi, how about venom power terrahunter xt? any inputs if this is good tire also?
BFGoodrich KO2 AT or Bridgestone Dueller AT
