Guys,
I experienced same problem with my Corolla 97 GLI Matic.
Madali mag low bat.
First - I changed the battery using Motolite Enduro (lasted only 8 months, down ulit), dinala ko sa service center sabi nila ok daw ang battery, check ko daw electrical ng car. Nagsawa ako sa kaka recharged at kaka pa check sa electrician sabi palit alternator....palit alternator din ako. Pero ganun pa rin.
Second - Palit ako battery Motolite Gold, 8 months lang low batt na agad, same problem, buti na lang meron me handy na pang jump start. Pina check ko sa service center, then ok namn daw ang battery....anyway i was not satisfied with their answers.
Third - Again for the third time palit ako battery yung GS (may indicator pa sia) medyo mura sa motolite and i read this grounding kit dito sa tsikot and its advantages. Ako mismo nag try, sinunod ko lang yung wire size at instructions. From battery clamp (Negative), i connect one wire bolted it to the body. One from engine to the body again. Ayun until now nawala yung problema ng madali mag low batt car ko.
Read more on grounding kit dito, marami matutunan.
thanks.
