Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Apr 2010
    My dash, park, and map lights flicker slightly Ride is a Terrano TD27T
    Replacement 70A alternator na ito (acquired brandnew, 4-6 yrs ago ata). Napansin ko nag ganito na siya nung nabasa ko ang alternator when changing the radiator hose
    Malakas pa naman kumarga, tested with a battery shop and may sarili rin akong VOM - around 13.9-14.2V when idle.
    May nabasa ako somewhere na i-set ko ang VOM ko to Vac mode, pag measure ko at the battery terminals, meron 30.5Vac, kelangan daw negligible ang presence ng AC sa system.
    Nag research ako and possible na rectifier ang problem neto. Mga magkano kaya ito? Ano ba usually ang wear and tear parts ng alternator and usual prices, para makapag-ready ako pag binaklas nila at isahang gawa na lang
    Or mas worth it bang i-swap ko na lang for a surplus higher-amp alt? Ang direct fit lang yata sakin is from an Urvan na 90A, kung may masuggest kayo na 100A+ with minimal bracket conversion mas ok. Thanks!
    May 2009
    Quote Originally Posted by ParticleX View Post
    hmmm. ngayon ko lang nalaman yang "presence of AC". maresearch nga din.
    kung rectifier, parang less 1k iirc. the usual wear & tear parts? carbon brush, bearing, pulley & belt, stator winding (insulation), rotor. atsaka oil seal (kung may kasamang vac pump)
    kung yung made in china na alternator iyan e baka nga ganyan din talaga ang lifespan. magpalit ka na lang (siguro) ng surplus pero kelangan din iinspect ang internal parts.
    as long as wala kang power consuming devices aside from oem e ok naman yang 70 amps.
    Feb 2009
    Check voltage drop across the I/P ground wires
    Apr 2010
    Quote Originally Posted by miked View Post
    Unipoint yung replacement, Taiwan yata. May minor sound setup ako and before summer, magpadagdag ako ng aux fan, so an upgraded alternator will be beneficial. Pano ba chinecheck ang used alternators? I-swap ko na lang siguro yung nakakabit para bawas pa sa presyo kung hindi naman nagkakalayo ang repair sa surplus alt.
    IP - injection pump? I believe ok ang wirings ko ngayon, I have it rewired already plus I added additional batt-engine-body ground using welding cable
    i think your generator (not alternator) is working fine. 30.5Vac though is too much maybe you mean 30.5mV (milli volts) the generator is producing filtered ac voltage (half sine wave - produced from the rectifier).
    IP= instrument panel
    Apr 2010
    Quote Originally Posted by t2erns View Post
    IP= instrument panell
    IIRC 30.5V nga yun since I set the VOM to display 20Vac, recheck ko mamaya
    Pati rin sa park and map lights eh may slight flicker din eh, dunno if mataas nga voltage drop sa instrument panel. Sa weekend ko na lang recheck kasi I have to cuss everytime I yank the dash sa hirap
    nag flicker din optitron gauge ng toyota namin. dont know where to start checking.
    May 2009
    battery....paload test mo muna.
    May 2009
    kadalasan may test rig yung mga surplusan...dalhin mo na rin yang DVOM mo.
    kung sinet mo sa 20 VAC yung scale sa meter mo e hindi mo mababasa yung 30.5 VAC. baka 3.05 VAC kamo. or even lower
    start ka muna sa battery (load test blah blah), terminals, grounding points then supply lines.
    Apr 2010
    Nakaset to 200Vac reading, around 29-30.5Vac ang display
    Already load-tested, and may spare akong brand new battery din. same
    batt terminals not corroded, cleaned
    Cleaned grounding points, ganun pa rin
    Sa mga napagtatanungan ko, around 5-6k ang 110A na alternator, supposedly Nissan so plug and play na lang. Parang ang mahal, nababasa ko sa forums around 2-3k lang ang surplus alts, or pang gas engines lang yun (without the vacuum(?) line)
Dash lights flickering
