Quote Originally Posted by miked View Post
kadalasan may test rig yung mga surplusan...dalhin mo na rin yang DVOM mo.
kung sinet mo sa 20 VAC yung scale sa meter mo e hindi mo mababasa yung 30.5 VAC. baka 3.05 VAC kamo. or even lower
start ka muna sa battery (load test blah blah), terminals, grounding points then supply lines.
Nakaset to 200Vac reading, around 29-30.5Vac ang display
Already load-tested, and may spare akong brand new battery din. same
batt terminals not corroded, cleaned
Cleaned grounding points, ganun pa rin
Sa mga napagtatanungan ko, around 5-6k ang 110A na alternator, supposedly Nissan so plug and play na lang. Parang ang mahal, nababasa ko sa forums around 2-3k lang ang surplus alts, or pang gas engines lang yun (without the vacuum(?) line)
