Results 1 to 20 of 22
    Feb 2012
    bkt kaya bigla nalang nasira battery ng liteace ko 2months palang ung batt
    dko lang ginamit ng 5days ayaw na ma icharge kahit kahit ipa charge ko
    ano kaya nangyari mga sir?
    Just guessing, the battery got drained during the five days you didnt use the van. Then the drained battery got damaged when crystals formed on the plates when left too long in a fully drained condition.
    I think you can still claim the warranty from the battery dealer. Hopefully you still have the warranty card and receipt.
    Oct 2011
    Quote Originally Posted by sotel View Post
    pa check-up mo sa supplier mo to find out kung ano nangyari sa baterya mo.
    Feb 2009
    what type of battery? if it is the agm type, it will not charge when it is completely drained unless you induce the charger by connecting another battery in parallel to your fully discharged or sulfated battery.
    Feb 2012
    motolite MF ung batt mga sir .
    malalaman ba ng supplier kung pano nasira
    Generally no. They'll just use their battery tester to see the condition of the battery. Once they see it's dead or low voltage, they'll have it replaced, although you might have to wait a day or so (with a temporary battery) while they do their "checks" (usually charging the battery to see if it will still hold a decent charge).
    May 2012
    Sir, its POSSIBLE that the battery is a 'rebuilt'. if you charge a battery at 10A, all six cells should show equal activity of hydrogen bubbles. if one or two cells are less active than the other cells, baka rebuilt yan, considering that the battery is a couple of months old.
    Important; never leave a battery in a discharged condition for too long.
    PS., If a two month old battery could not be recharged, use a specially built battery charger that can charge up to 48v. Increase the voltage by 2v steps until you can read an ampere reading. The ampere reading is increased up to 10a. As the battery is gaining its charge, gradually reduce the voltage by 2v steps. When the battery is stabilized at 13.8v, let charging continue for 15-30 minutes. Hydrogen bubble activity should be the same for all 6 cells, otherwise, the less active cells will not retain their capacity.
    During this procedure, always monitor the charging process which could be from 30 minutes up to an hour. Tnx.
    is this battery a brand new factory unit? or is it a rebuilt unit by an independent rebuilder? if it's factory, then you are entitled to a brand new replacement.
    have your car checked, too. see if there's a low battery drain even when off..
    nangyari na yan sa corolla small body ko 5 days ko di nagamit, kahit i-start lang di ko nagawa, ayun ayaw na niya mag start, at di macharge, nadischarge daw yung battery ko,
    Feb 2012
    brand new po ung batt sir. ang problema wala na ung resibo
    - - - Updated - - -
    Quote Originally Posted by d'flash View Post
    pina palit mo ba sir?
    [QUOTE=sotel;2030177]brand new po ung batt sir. ang problema wala na ung resibo
    baka puede pa.. if the store is computerized, they may be able to find your receipt file in their computer. honorable yan.
    - - - Updated - - -
    pina swap ko nalang sa brandnew.
    Feb 2012
    mga sir sira nanaman battery ng liteace ko 2 months palang ulit ganun nanaman ung nangyari ayaw na ma charge
    did you have your electricals checked? baka may parasitic load ka.
help bigla nalang nasira battery ng liteaace ko
