Results 11 to 20 of 24
- Dec 2008
- 105
December 10th, 2010 12:46 AM #11Hi.
Just remembered when buying fuses na yung nagkalat sa mga auto supply ay mga china made fuses. Those that have plastic na kita mo yung bakal sa loob.
Try to search for non-China fuses na yung plastic ay di mo kita yung bakal sa loob.
By comparison, the 10amp fuse of these two makes do not have the same thickness ang bakal. So I suspect, the china-made fuse tinipid ang bakal. Hehehe.
My non-China 10A fuse has thicker metal than the China-made 20A fuse.
Re headlight wattage, ang taas kung 155watts. Ok lang if 100 watts. According to OSRAM dealer, they discourage going about 110 watts. Dahil sa init ng bulb, pag naulanan, prone na mabasag ang bulb due to hot-cold environment.
HTH.
- Sep 2010
- 15
December 13th, 2010 12:06 AM #12guys napundi lng pala yung bumbilya q pero bago bili naman un.. narva na bulb yung napundi.. pinalitan ko na ng osram na bulb..
- Jul 2010
- 22
January 16th, 2011 11:11 AM #14query lang po sa inyo, ok lang po ba if I use the 85w H7 bulbs as replacement sa stock 55w. meron pa ba ako imodify sa wirings? or ma-void kaya yung warranty ng car? thanks po.
January 18th, 2011 02:09 PM #15
FYI mga paps,
to determine current drawn by any electrical load, follow this formula: Power (P in watts) = Current (I in amperes) x Voltage (V in volts)
given the specs above as our example:
Before: 55W, 12V system
P = IV
55 = 12I
I = 4.6 Amperes, thus a 10A fuse will do.
After: 155W, 12 V system
(same formula)
I = 12.92 Amperes, thus the 10A fuse will blow.
Fuses should be loaded approx 80% of its rated ampacity.
Example: Load = 100 A
Fuse rating = 80 A
My suggestion is go back to your stock specifications...for mods, upgrade your system plus the wires should also be replaced to a higher gauge if the stock wire will not also hold the electrical load.
January 27th, 2011 09:30 AM #16
question lang po, headlight ng corolla xe 95 model gumagana yung isa pag park light and high beam pero pag normal wala ilaw, kailangan na bang palitan?
Tsikot Member Rank 3
- Jul 2004
- 1,540
January 27th, 2011 09:51 AM #17
- Jun 2010
- 354
January 27th, 2011 11:59 AM #18ano po mga kailangan if nag upgrade ka ng headlight? baka kasi magka problem din ako...
- Jul 2004
- 1,540
January 27th, 2011 12:22 PM #19
- Sep 2010
- 9
May 13th, 2011 02:36 PM #20Hi Guys,
My ride is a honda city 2006 idsi. Kagabi napansin ko na walang ilaw yung left headlamp. I tried using high beam, umilaw naman parehong headlamp. Sa low beam lang ayaw gumana nung left side. Ano kaya ang problema? Thanks in advance.
