Results 1 to 10 of 50
- Sep 2005
- 8
November 10th, 2014 04:10 PM #1Sirs, the fog lights of my Innova is H16 12V 19 watts. H16 bulbs are very rare, can I use H11 12V 55watts instead? Is there any danger? BTW the sockets of H11 and H16 are the same. Fit na fit sya sa housing. Thanks
- May 2014
- 52
November 18th, 2014 11:49 PM #2
November 19th, 2014 12:35 AM #3
H16 is normally for Ford. The H16 in Toyota foglamps are actually H11 base.
The PGJ19 base series common with H8, H9, and H11. Osram used H16 for their 19W bulb of this series.Last edited by confused shoes; November 19th, 2014 at 12:54 AM.
- May 2014
- 52
November 19th, 2014 02:44 AM #4
November 19th, 2014 03:24 AM #5
Since mas mataas ang wattage ng H11, baka di kayanin ng original harness. Baka need mo ng harness kit with relay. If gagastos ka lang din for harness kit and relay, better na rin to settle for 3000K or 4300K H11 HID
Sent from my LT26i using Tapatalk 2
- May 2014
- 52
November 19th, 2014 03:34 AM #6
- Aug 2012
- 2,767
November 19th, 2014 09:07 AM #7wala bang H16, 19W bulb sa Toyota casa? hindi naman siguro kamahalan kung bulbs lang, less hassle pa. Fog light color temperature is normally 2600K to 2800K. this gives best results. HID for fog lights are useless.
November 19th, 2014 09:27 AM #8
Our 2008 Innova is using 51W foglights H11,- all stock.
“The measure of a man is what he does with power – LJIOHF!”
Duterte for President of the Philippines in 2016!
25.1K:dog2:
- Aug 2012
- 2,767
November 19th, 2014 09:46 AM #9*TS: there you go, problem solved. use 51W, H11 instead or even 55W should be no issue.
November 19th, 2014 10:08 AM #10
Ano nga kaya meron sa Toyota at puro H16 na fog lamp bulbs nila? It's useless eh ang dilim. Pati Innova pala at Super Grandia na dati naka H11, naka H16 na rin.
In my experience ok naman 3000K sa fogs..
Although I think good for 6 years naman normally ang tires, personally I will look for newer ones....
Finding the Best Tire for You
