Originally Posted by
autobahn
Baka meron na naka experience sa inyo. My ride is a 1994 lancer glxi. Last monday, on the way to work all is normal..but when a bus suddenly swerved in front of me, napa preno ako bigla at sabay busina..biglang namatay yung makina. akala ko medyo nabigla lang so i started the engine..okay naman. it happened again sa buendia, ng may taxi nag cut so preno sabay busina, namatay ulit. i called my friend na mechanic at pareho din kami ng car. sabi sa akin, same problem daw kami at pinalitan nya yung hydrovac nya. so that's what i did, since 20 years na rin yung car at di pa napalitan yung hydrovac. but when i changed yung hydrovac, satisfied naman ako kasi mas malakas na ang preno nya at kahit biglain ko pag preno okay sya. little did i know, sa busina pala..nung may tumawid bigla na pedestrian at bumisina ako ng 5 seconds biglang namatay ulit makina. pumarada ako sa shoulder tapos pinatay ko aircon at binusina ko ulit for 5 seconds, bumaba ang rpm hangang namatay makina. i went to my suking electrician..pinalitan namin busina. ganun pa din ang issue, we isolated the electrical line tapos dinerekta nya sa battery yung busina para gumana pero namatay pa rin makina. di ko alam kung ano problema, all is normal idling, lights, etc..wala ako check engine. may volt meter ako sa car nag cha charge naman alternator, hope you can help me mga sirs. thanks in advance.
