Results 11 to 16 of 16
February 13th, 2014 02:19 PM #12
solution dyan is hwag bubusina ng matagal.... parang pinipitik pitik lang.....
seriously, it can be the grounding or the horn relay.
- Oct 2009
- 2,271
February 13th, 2014 04:53 PM #14amphere meter dapat nilagay mo para malaman mo kung bumabagsak ang amperahe o lakas ng baterya mo kapag bumubusina ka..
tanggalin mo ang busina at subuka mong lagyan ng 2wires at paandarin mo tsikot mo saka mo i rekta ang busina sa + at - ng baterya mo.kapag namatay malamang mahina na baterya mo..
kapag hindi naman namatay malamang sa electrical wiring ng busina mo may grounded
- Aug 2003
- 5
February 23rd, 2014 01:12 PM #15Sirs, sorry for the late reply. Medyo busy sa work at kaka-isip ng possible causes and fix regarding sa problem ko. Here are the things I have done for the past 8 days:
1. Replaced the old battery with a new one- since mahina redondo ng starter pag umaga and 3 years and 2 mos. na rin. But I still experience the same problem.
2. I bypassed the original wiring. Nagkabit ako ng new relay malapit sa battery (yung electrician sa + ng battery kumuha ng power source), hinanap yung horn button switch wire tapos pinutol na ang linya sa original wiring, at dinugtong ang bagong linya ng horn sa button switch wire. Kumbaga isolated na yung original, at new wiring na busina. - Same problem pa rin. But this time- intermittent sya, sometimes kahit ibusina mo ng matagal hindi namamatay makina, or nag drop ang rpm..pero pag minsan, 2 seconds lang mo honk yung horn-bumabagsak ang rpm and eventually the engine will die.
3. Replaced Hi-Tension Wires (since 4 years old na and may visible arcing when i checked it last Thursday night) - same problem pa rin.
I have checked my grounding -okay naman; the wires going to the ignition switch and ecu-hindi naman mainit and intact pa rin. I've read several forums sa when I search google that are similar with my problem kaya lang walang resolution information. It is really a puzzle, if i turn on for example the headlights, signal lights, hazard, wipers, aircon hindi naman nag drop ang rpm ko katulad ng pag nag bubusina. nakakatawa pa, pag naka engage ang aircon-hindi namamatay/drop ang rpm pag binubusina mo. so really weird. pina-check ko na sa aircon shop na pinagpagawaan ko ng aircon ko prior to this problem I am encountering-ang sabi wala sila nagalaw na electrical line. Meron ba kayong kakilala na electrical expert on efi engines? Thanks in advance.
February 24th, 2014 01:19 PM #16
grin:
hanap ka iba electrician, meron kase mas magaling gumawa sa iba. baka di naman expert elekrisyan mo kase dapat kung bihasa yaan alam niya at madali nya ma trace problema mo baket ganiyan namamatay kapag nag bubusina ka. kapag nauurat ako sa mga gagong driver higit pa sa 5 segundo kung businahan ko e, hindi naman namamatay traktora ko.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
