Results 1 to 10 of 19
    Oct 2014
    ask an expert to look at your set-up, po.
    fuse... wiring... housing...
    if the (stock, i assume) fuse keeps blowing kasi, your lights are probably drawing more current than what the car's wiring was designed for.
    you might have to upgrade everything and not just the fuse.
    btw,
    i noticed that many car drivers use their bumper lights and not their headlights.
    are they aware that sometimes, them bumper lights actually generate more glare than the stock headlights?
    I used the lights for 5 months without any problem until the problem occured a few days ago. Is it possible there's a short somewhere? And to your other question, I use both my headlights and foglights when driving at night. If it's well lit I only use my headlights.
    Quote Originally Posted by Valharth1031 View Post
    was this a do-it-yourself thing, or was it done by someone else?
    Oct 2014
    I had it installed by a shop. I got it from LED Lights PH in Antipolo. Check out their fb page if you're unfamiliar. Unfortunately I'm not great with car electricals so I would never DIY anything electrical.
    normally,
    my suggestion would be to bring it back to them for trouble-shooting.
    there is definitely something wrong if your fuse blows twice...
    the other side of the coin is,
    they may not be fully versed in what they should be fully versed in...
    what would i do?
    i'll probably feel my wiring and see if they get "too hot", and go from there...
    but so many things can be the matter...
    you need the experts, if i may opine.
    Oct 2014
    normally,
    what would i do?
    Thanks for the reply. I'll try going back to them one more time. If not, I'll look for a good electrician. Do you have any suggestions for good electrical repair shops?
    not me.
    puro stock kasi ang sakin.
    but i am sure there are folks here who can point you in the right direction.
    so what city/province would you like?
    Oct 2014
    not me.
    Just here in metro manila. preferably manila or qc
    Not just any good electrician. Some cars these days, esp the euros, may require canbus decoder/anti flicker chips or harnesses to make replacement LEDs work & work w/ longevity. Some have fans to keep em from overheating. Look for one who's familiar w/ your model's lighting circuitry & needs. Or check forums, HRV ones, to be specific. They should have good recommendations on products that are known to work & those to stay away from.
    Here's a basic H11 swap How-To on a CRV. Shouldn't be too different from the HRV.
    2018 Honda CRV LED Headlight Install - Auxbeam F-T1 (H11) Bulb - YouTube
    Jun 2011
Fog Lights won't turn on - 2017 Honda HRV
