i'm on my second piece of 10mm LED wedge base used as clearance/park lights on the front. replaced the 12volts 5 watts halogen with a 10mm 6 led wedge equipped with 2 resistors in parallel with each other. about 300 ohms as per the color code.
problem: LED was flickering at first. then 3 (out of 6 per piece) leds were out until all are dead.
installed another one thinking it could be the LED but problem is occuring again. replaced the previous halogen bulb and it does not flicker.
