Results 11 to 20 of 51
September 11th, 2006 09:26 AM #11
September 11th, 2006 10:00 AM #12
September 11th, 2006 10:43 AM #13
basta sa akin basta gamit ko na ng 1.5-2 yrs palit na ng bago basta tapos na yun warantty, maintenance free nga pala lagi gamit ko para wala ng check-check kung meron mga tubig o wala? ano nga pala advantage ng MF sa hinde bakit parang marami pa rin gumagamit ng ordinary batt, considering isa pa yun sa icheck mo
September 11th, 2006 10:49 AM #14
Mas mura kasi conventional batteries (minsan malaki talaga price difference depending on brand and supplier).
Checking water level is not that hard. Sinasabay ko lang when I do the underhood engine check (fluids, filters, belts, etc.). Most batteries have a transluscent casing already. You don't even have to open the fill holes to check fluid level. Eyeball mo na lang while vehicle is parked on level ground.
Mura din lang battery water. Php15.00 ata.
Parang mas nagtotolerate ng recharging ang conventional. Nabubuntisan ako ng battery minsan kapag MF ang kinabit sa charger. Nadischarge nga pala ito after alternator failure (hindi pa sira ang battery that time).
September 11th, 2006 01:16 PM #16
Yup, oks 'to. I got one of these 3 yrs ago sa Uniwide. As I recalled it was bargained at around Php300 na lang. Mukhang nag-bulk import sila from China or something, and marami pa silang excess stocks. When I wanted to get another one, ubos na. Now, I'm seeing the exact thing being sold in some car accessory shops, but for over Php1k, some even over Php2k!
- Mar 2006
- 57
September 11th, 2006 02:39 PM #17
September 12th, 2006 06:00 PM #18aside from the slow redondo, what are the other symptoms of a battery nearing its end?
Ask ko lang naka by pass na ba Yan or servo pa din ang gamet mo
4g15 rare Idle motor (servo)
