Quote Originally Posted by kikoteng View Post
hello all !
good day to all.
ride is a toyota corolla xl 2000 ... 2e engine ...
noticed my ride vibrates erratically when aircon & headlights on.
so, had my electricals checked by the neighborhood elec shop ...
after checking voltages with aircon / headlights on, he was quick to offer trade-in for a recon unit instead of repair.
I'm wondering whether our neighborhood auto electrician has made a correct diagnosis. So, i took my digital voltmeter & took the ff readings:
1. idle - aircon off - headlights off - 14.04 volts
2. idle - aircon off - headlights on low beam - 13.16 volts
3. idle - aircon off - headlights on high beam - 12.95 volts
4. idle - aircon on - headlights off - 13.16 volts
5. idle - aircon on - headlights on low beam - 12.25 volts
6 engine off - battery voltage is 12.5 volts
Alternator belt seems ok, not loose. Changed about a year ago.
battery is enduro 2sm ... about 1 year 9 months old.
Have never done any maintenance on the alternator for the past 4 years.
I've read several threads at tsikot. From what i have read, everything seems ok except for #5. Some say its ok. Some say not. A
So, can anyone tell if my alternator is ok or is it in need of repair or replacement ?
Thanks in advance for your replies and advise.
you mentioned the car vibrates when a/c is on or when there is electrical load. i would check and adjust the base idle first, then fast idle when there is electrical and/or a/c load (your car might be equipped with an idle air control, clean your throttle body and idle air control system too)
