Quote Originally Posted by genobreaker47 View Post
update after one year. lol
its a toyota fx nga pala, so definitely stand-alone/independent yung central lock system niya. also i've traced the wires from the doors and it leads only to the module.
i think it's a negative trigger type (?) dahil meron part na nakahiwalay yung green and blue wires (the pairs going to the passenger doors) and pag dinikitan ng ground ay mag-lock/unlock yung passenger doors but not the driver side door.
is there a way to test the driver side door actuator kung possible siyang lagyan ng switch? someone told me that yung brown and white wires ang sw1 and sw2 (switch 1 and 2 siguro), i've tried linking it sa ground pero walang nangyari.
natatakot naman ako lagyan ng live supply baka masunog. sayang ang actuator sa experiment LOL.
thanks.
Yup its possible to put a switch on the dashboard. The driver side actuator has 5 wires use the brown, white and black wire.
If you join the brown wire with the black wire the actuators will go up. If you join the white wire with the black wire the actuators will go down.
Now you can then tap that and put a switch on the dashboard.
