hi,
i am still in the process of learning and troubleshooting my own car and i just wanted to ask this about the distributor and spark plugs...
the distributor that i am using does not have an external coil. it DOES NOT have a contact point inside as well. the ignition coil is inside the distributor housing. what i have inside the distributor housing is an igniter and a pick up coil (hall effect).
- dumb question, how does the igniter in the distributor work?
- how would you know if you have a weak spark?
- is this a myth or fact, a spark test should show a bluish white spark and NOT a yellow/orange spark? yung yellow/orange spark daw ang weak spark.
- given that i have a good set of hiten and new plugs, what do i have to replace in the distributor?
