Results 1 to 3 of 3
    mga bossing bago lang po ako d2. bka po may mkatulong. ung HID ko po ksi biglang namamatay minsan ung sa right side pero kpag pinatay ang switch tapos binuksan uli, umiilaw nman sya. ano po kya ang problema mga bossing? salamat po ng mdami.
    May 2007
    Check your ground connection. Make sure that is clean and making good contact. Test the bulb (on the right to the left, pagpalitin mo ng bulb) just to make sure that bulb is working properly to eliminate that bulb is being bad. Use an omh meter to test the resistance and find out the manufacturer specs and this will tell you if they are in range if not then the ballast is bad and should be replaced.
    Quote Originally Posted by tsiwawa View Post
    probably loose connections lang yan bro...
help nman po..Namamatay na HID
