Results 1 to 9 of 9
October 3rd, 2011 12:31 AM #1
Problem 1: gauge light
maliwanag naman siya pag kakabukas lang ng kotse,,pero pag tumakbo na..medyo nag didim na siya..hindi naman nag fflicker.. ano kaya problem?
Problem 2: power antenna
hindi siya tumutuloy pag direcho start na engine..ang technique ko is buksan ko muna yun kuryente ng kotse (half click lang) then siyaka ko bubuksan radio then tuloy tuloy na yun angat ng antenna and consistent siya pag ganun yun style.ganun din pag bababa ko antenna same procedure. fuse ba ito? may separate fuse ba ang power antenna?
TIA
October 3rd, 2011 12:25 PM #2
October 3rd, 2011 12:39 PM #5
October 3rd, 2011 12:43 PM #6
anung pwedeng solution sir? akala ko power antenna na yun mismong sira.
October 3rd, 2011 12:48 PM #7
locate the ground wires, clean surface contacts and re attach snug tight. as for the power antenna, we used to spray wd40 on the antenna rod itself and run it up and down until the whole rod is lubricated. this process prolongs the life of the plastic geared strip drive and the plastic clutch drive of your pwr antenna
October 3rd, 2011 06:35 PM #8
baklasin ko yun panel gauge then make sure na they are properly connected yun mga wires sa likod nun? dalhin ko na lang siya sa magaling na electrician para sure. hehe.. thanks sir!
- Jul 2010
- 570
November 1st, 2011 01:19 AM #9Possible marumi contact ng Battery terminal. Need to install grounding kit kung luma kotse. Linisan na rin yun contact ng Ignition Switch. Check battery voltage kung umaabot ng +13.5V pag umaandar ang makina.
I don't know why people continue to try and take Kennon Road from Rosario. Its perpetually being...
2023 Toyota Wigo
