Results 1 to 14 of 14
    pag nag mamulfunction yung speedometer and tachometer ng gauge, repairable pa po ba sha? my car is a corolla bigbody xe
    tia
    Jan 2009
    Quote Originally Posted by smewth View Post
    tia
    Please elaborate. Malfunction could mean working erratically, intermittently, or totally inoperative. All of which requires different approach in figuring out the problem.
    Are the other gauges affected? How's your fuel gauge?
    Are their other gauges that are affected? How's your fuel gauge?
    all other gauges are working fine and also the lights are working ok...mabagal lang gumalaw yung speedometer and tachometer ...what could be the cause of this?repairable pa po kaya ito?
    Jan 2009
    Inayos ba yung radio recently? I have a hunch that the brown wire from the instrument cluster is not grounded properly. The manual says that the brown wire is attached to or near the right side of the radio chassis.
    Dec 2008
    Sir oj88. yong sa akin ayaw na gumalaw ang odometer. pwede ba palitan yon or pwede repair lang
    Jan 2009
    Quote Originally Posted by Jan Elton View Post
    Not sure. Kung analog odometer, malamang may sira or stuck na gear sa likod ng odometer.
    Dec 2008
    analog odo. meron ba available replacement? try ko nga kalikotin
    possible din po kaya na cable ang sira? also follow up question ano po ba type ng odometer meron ang XE corolla bigbody...analog po ba or electronic ba yun isa?...and 2nd followup pag gear yung sira napapalitan pa ba yun or hindi na?
    last and final question is where can i bring my gauge para ma check kung ano talaga problem...any recommended shops that can fix or have knowledge sa mga gauge?
    tia
    added facts: wala po inayos sa kotse bigla na lang po nag malfunction yung tachometer pati speedometer. Also minsan lang gumana pala yung dalawa. Pag gumana sobrang liit lang ng galaw. Hindi lumalampas ng 500 rpm while yung speedometer pag 100 na takbo mo, 50 lang reading niya yung speedometer and tachometer
    Jan 2009
    Maybe a grounding issue. When I studied the schematics, the fuel gauge, tach, and speedo share the same ground. This ground wire (brown) I'd look at first. It's supposed to be attached to the radio chassis.
    thank you very much sir oj88 for all your help will be checking the ground
    follow up question....how about the odometer? pag hindi po umiikot ano po usual cause nun? repairable pa po ba yun?cable po ba nag papaiikot nun?
    Jul 2010
    tia
    buhayin ko lang po tong thread na to. ask ko lang po sir smewth kung naayos nyo pong yung problem ng gauge nyo? ganito rin po problem ng auto ko, parehong pareho po tayo. at pareho din po tayo ng auto, corolla xe din po ung akin. paano nyo po naayos?
    Jan 2012
    up ko lang po. may problem din sa corolla 90 ko small body. hindi accurate kasi yung speedometer ko pag naka 40km/h ka biglang umaakyat sa 100km/h at kung tumatakbo ka naman ng 80 pataas umaakyat sya sa 120km/h.. usually kasi dumadaan ako sa macapagal merong speed limit dun na 60 minsan di ko n alam kung accurate pa ung speed ko kaya sinasabayan ko nalang yung ibang sasakyan para makipantay ako sa speed nya.
    repairable din po ba ito?
    recommended shop din po na nagkakabit ng tachometer kasi minsan magalaw yung idle timing at sa ac on timing.
quick question lang po re: gauge
