Quote Originally Posted by Asus700 View Post
diba dapat pag nag on ang compressor sasabay mag on ang condenser fan?
papano kung hindi na sya sumasabay, ano kaya ang sira?
dapat pag on ng AIRCON sasabay yung CONDENSER FAN, if not probably may sira yung motor or wiring.. pag luma na kotse eh madalas yung motor ang sira.. you can buy surplus but to be sure pa check mo muna yung power supply nya kung ok baka kasi wiring lang problema..
using the AIRCONDITIONER without the condenser fan will cause high pressure builp-up on the airconditioning system...!! hindi lalamig yung evaporator kasi hindi ma-dissipate yung heat sa condenser dapat talaga sabay yung sa pag on ng AIRCON COMPRESSOR...
FYI, meron PRESSURE SENSOR dun sa FILTER DRIER ng AIRCON SYTEM, its function is not to control the condenser fans but rather to PROTECT the airconditioning system from LOW FREON Pressure.. if your system goes low on freon, your compressor will not turn-ON to protect it from further damage..
there are 2 FANS installed in a car.. yung isa for the AIRCON CONDENSER and yung isa for the RADIATOR.. yung fan ng radiator will AUTOMATICALLY turn - on when the Engine reach a certain TEMPERATURE to cool down the radiator... better to check kung condenser fan nga or radiator fan.. kasi yung radiator fan naka depende ang pag-on sa engine and not on the compressor... (but some cars when you turn on the AIRCON will also turn-on the RADIATOR FAN and CONDENSER FAN simultaneously)
