Results 1 to 10 of 43
February 18th, 2016 05:19 PM #1
isuzu tfr 4ja1
before: 13.8 -14.3 volts (full load to no load)
tapos naging below 12.5 volts and below. kahit na irev mo ng mataas e hindi na masyado lumalampas ng 12.5 volts.
so inassume ko na pudpod na carbon brush. so ayun baklas ng alternator at nung nakita ko carbon brush e abnormally short na yung isa tapos mahaba pa yung kapares nya na brush. so ang ginawa ko pinalitan na lang. kasama rin syempre yung oil seal.
tinesting ko rin yung stator at coil for continuity, etc. kaso mabilisan dahil may lakad sana ako netong hapon.
kaso ganun pa rin yung charging voltage after nung supposed to be "repair"....
dalawang beses din pumutok yung fuse controlling the charge relay at fuel cut solenoid.
kapag icoconnect ko na ang battery e nagki-click yung charge relay kahit naka-off sa susian. aba e 2.5 amperes din yung current draw nung sinukat ko. pero kung disconnected yung B (charging) terminal nung alternator e hindi nagki-click yung charge relay.
ang nakakawindang pa ay nawawala ang battery warning at fuel sedimentor warning lamps kapag isasalpak ko yung fuse sa circuit (kung saan nagkaroon ng 2x na blown fuse)
ewan ko. mejo pagod pako kaya tinigilan ko muna.
ayoko lang kasing palitan agad alternator at malaman na simpleng wiring problem lang pala.
nangyari na ba sa inyo ito mga kaibigan? kung oo, anong ginawa nyo?
tulong!!
- Apr 2010
- 742
February 19th, 2016 09:06 AM #2Could be the IC / voltage regulator? Dunno how to test this without consulting a electrical shop. Guess lang since you have done an extensive troubleshooting already
- 54,299
February 19th, 2016 09:21 AM #3"IC" inside alternator. i had it checked by an alternator shop. replacement of the IC solved the problem (non-isuzu vehicle, me).
February 19th, 2016 10:57 AM #4
removed the alternator again. bawat isa sa tatlong diode ay chineck ko ang continuity
488 ohms tapos 1238 ohm with the test leads reversed. bawat isa sa tatlong diode ganyan ang reading. hindi ba dapat zero ohms tapos infinity?
tapos chineck ko uli yung wiring ng charge relay. with the test lead connected to the negative battery cable, zero ohms (continuous) ang reading when connected to the terminal socket #30 and #87. ayon sa aking pagkakaalam, ang 30 & 87 is the load circuit. tapos 30 is connected to the positive side and 87 is to the load. pero bakit continuous?
pinapanalangin ko na nga sana ic or diode lang para straightforward pero parang maghahanap ako ng short to ground neto ng matagal.
namomonkey wrench nako a.
February 19th, 2016 11:08 AM #5
- Mar 2010
- 2,275
February 19th, 2016 11:28 AM #6
February 19th, 2016 11:50 AM #7
February 19th, 2016 12:00 PM #8
i have a dmm with a diode check but reads ohms i think. not volts. it reads 1206 and 460 . diode trio is still connected to field coil and regulator.
what puzzles me is that the 15 amp fuse (code CB-3) for the charge relay, alternator, fuel cut solenoid, thermo switch keeps blowing.
with the key on (engine off), the battery (charge) and fuel sedimentor warning lamps goes off when i put in a fuse on CB-3. these two lamps comes back on when i remove the fuse. btw, these two lamps are connected to each other via the charge relay.
February 19th, 2016 12:26 PM #9
February 19th, 2016 02:05 PM #10
on a side note, sa loob ng isang taon sa akin ng sasakyan e lower than 12.6 volts at idle at naka-on lahat ng loads. lights, AC, radio.
pero once irev ko kahit sa 1,000 rpm lang e pumapalo up to 13.8 - 14 volts. for one year ganyan kapag idle with full load. tapos hindi pantay ang pudpod ng carbon brush.
e ngayon kahit irev higher than 1,000 rpm di na kayang umabot ng 13.0 volts
ewan ko kung konektado ba ito sa problema ngayon.
VinFast VF 3
