Results 1 to 12 of 12
    Jan 2009
    My UltraGauge (UG) arrived in the mail this afternoon. It took me a while to figure out where to put it, as it can't be mounted where my ScanGaugeII was (under the A/C controls). Anyway, planning, installation, and configuration of the gauges took about an hour and a half.
    This is what I had to start with. The fog light switch used to be in the center and I had to move it to the left-most slot to give room for the UG.
    Stuck some 3M Dual Lock fasteners on one of the blanking panel and behind the UG mounting bracket.
    Attached the bracket.
    Mounted the UG on the bracket and powered up (connected to the car's OBD-II/DLC connector)
    I routed the cable in a way so it won't get pinched by the door when it is closed. It goes down inside the weather strip, towards the MICU/fuse box, went under the steering column, and finally to the DLC connector. Tidied up a bit with a few zip ties.
    Close up.
    Total investment: $69 + S&H + Local Taxes
    UltraGauge Site: UltraGauge Automotive Information Center and OBDII Scan Tool
    I'll try to write a mini review soon.
    this is nice. so it works exactly like Scanguage right?
    Jan 2009
    ^ Yes. More or less.
    May 2011
    Musta ultra gauge mo bro? Pwede ba mabilad sa araw? Planning to get mine.
    Sent from my GT-I9505 using Tapatalk
    Quote Originally Posted by 3GEMS View Post
    Okay lang mabilad sa araw yung ultragauge sir. Yung akin naglooloose yung sa obd2 port pag natatagtag.
    May 2011
    Quote Originally Posted by beni23 View Post
    Pano ka nag ka unit bro? Nag paship karin dito sa pinas? Pwede kaya pabili ako sa US then pa lbc ko nalang sa kamaganak?
    Jan 2009
    When I sold my Civic, my UltraGauge fell into disuse. The Innova is not OBD-II compliant so the UG doesn't work on it.
    para madali try mo bili sa amazon tapos padala mo via johnny air cargo. i tried this recently and in a week's time nakuha ko naman iyong purchase ko hassle free
    actually ganito siguro gagawin ko kung i-push through ko bili ng blue driver obd2 blue tooth scanner. i'm just not sure yet if it works on the monty seamlessly
    May 2011
    Baka for disposal na ultragauge mo. Bilhin ko nalang hehehe.
    May 2011
    Plan ko is bilhin ko online papadeliver ko sa kamag anak sa US then sila na pa LBC dito sa pinas 30 dollars daw. Gusto narin dagdagan order ko para benta yung iba para offset kahit yung gastos q sa delivery.
    Nakigroup buy ako dati sa fordclubph bro. Try mo magjoin sa forums nila then punta ka group buy kung meron pa. I think around 4,500 ko ata nakuha.
    May 2011
    Active reader din ako don bro. 2014 pa yung group buy and nag ask narin ako wala na. Mukhang sa US na nga ako makakuha.
UltraGauge DIY
