Results 1 to 2 of 2
January 4th, 2010 12:18 PM #1
Mga guru's, after ko magpa-engine wash umilaw ung Check Engine light. Naisip ko baka may nabasa na hindi dapat kaya kinabahan ako. What I did was try resetting the ECU by removing the battery then putting it back, at after starting up the engine eh nawala naman. My question is do I still have to check kung meron ngang naapektuhan because of the engine wash o am I all good after what I did since nawala naman na CEL? TIA!
- Oct 2009
- 72
January 13th, 2010 08:19 AM #2The best way to deal will these is to get the code and know which sensor or actuator is the wet-prone problem, in this way you can preempt future problem.
Cost-wise what you have done is also the best, but if re-occurs again, have it scan. An Ounce of Prevention is better than a pound of cure.
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
