Results 1 to 10 of 13
- Jul 2012
- 11
August 13th, 2013 02:38 PM #1mga bossings,
ask ko po sa inyo kung meron na sa inyo naka-try ng car voltage meter?
Qoo10-Singapore - Automotive - ?Car LED Battery Tester? Using Cigarett...
di ko po kasi alam kng paano ma-check kung ok pa yung battery.
naiwan ko yung headlight ko na nakabukas ng maghapon.
kaya natatakot ako at baka bigla na lng tumirik ako sa daan.
plano ko po magpabili ng car voltage meter...yun nga lang di ko sure kung advisable or reliable ba sya.
hehehe.
thanks!
August 13th, 2013 02:46 PM #3
old cars had voltmeter and ammeters. to make the car's instrumentation simpler. manufacturers replaced them with idiot lights or charge malfunction indicator light. of course the predictables (voltage is regulated when the engine is running and the alternator is working satisfactorily) don't need elaborate gauges. similar to aircraft instrumentation. the flight crew, the pilot, co pilot, navigator and flight engineer tend to panic if one gauge is fluctuating or some warning lights flicker. but with this similar scenario, on military aircraft, should it happen while forward deployed in a hostile area, the crew will try to fly it back home. if the malfunction happens in say for example hawaii, puerto rico or japan or europe, the flight crew will use this as an excuse to stay at club med for a considerable time. the warning lights should suffice as long as you do your routine preventive maintenance.
unless you want it to look like this
http://forums.watchuseek.com/f258/c-...tos-99999.htmlLast edited by jick.cejoco; August 13th, 2013 at 03:00 PM.
- Jul 2011
- 1,711
August 13th, 2013 02:49 PM #4maganda sha as an accessory pero other than to monitor battery life parang hindi sha worth it.
punta ka na lang sa car battery store, normally free service naman un pag check ng battery status, pwede ka pa mag second opinion sa ibang shops.
August 14th, 2013 09:51 AM #5
hindi mo rin ma chcheck yan diba? kasi when car is running ung alternator na nagsusupply ng voltage hindi na galing sa baterya.
- 54,215
August 14th, 2013 10:34 PM #6in my opinion... no.
baka mas matakot ka lang dahil ma-worry-worry ka sa mga numerong makikita mo diyan.
i had one 20 years ago.. never got the chance to appreciate it. never missed it at all.
August 14th, 2013 11:17 PM #7
I used this before. Dami nagkalat sa banawe acc shops, even blade/concorde.
Helpfull in a bit. Me threads na rin dito about car batts.
Afaik, below 11.9v cannot start the engine na. While idle or rev a bit voltage will play bet 13-14v.
Yun iba naman, 'upgrade' to reduction type starter which can still start your car at 6v ata (not sure sa min voltage requirement)
By experience sa motolite, usually starts to fail on 25th to 26th month nya (past the 24mo warranty). Charge/power doesn't stay long na.
Kun manual ka, no need to worry at pwede itulak (in case no issue with electricals when batt fails o discharged).
August 14th, 2013 11:22 PM #8
mas maganda pa cguro imo kung bibili ka ng battery booster clamp or the battery booster itself kung natatakot ka na biglang madiskarga ang iyong baterya.
- Jul 2010
- 570
August 15th, 2013 10:37 AM #9Maganda rin meron Battery Voltmeter para sa peace of mind. Lalo na kung luma na Alternator or car Battery ng kotse.
Minsan namamatay ang engine kung nasa traffic na naka on ang aircon, stereo, headlamp. So, kung makita mo na bumababa ng DC Voltage ng battery ay bawas mo muna load. Gaya ng Off muna high beam at mag low beam ka na lang.
Meron ako ginawa na DIY Battery Level indicator. Kasama na ang Tachometer at Coolant Overheat alarm. Wala kasi niyan sa mga lumang Lancer Itlog.
- Jul 2010
- 570
August 15th, 2013 11:13 AM #10If you remember. Naka parallel connection ang Alternator sa Battery. Then ang DC Voltmeter ay parallel connection din sa Battery. So any voltage reading ng Alternator at Battery ay ma monitor ng DC Voltmeter.
During high rpm ay ang alternator ang mag supply ng dc voltage sa kotse while charging the battery. Pero during low rpm ay mahina ang charging ng alternator at yun charge ng Battery ang additional supply para sa electrical ng kotse..
Megawatt charging: https://www.youtube.com/watch?v=usUxO7y4z_E
BYD Philippines
