Page 1 of 2 12 LastLast
Results 1 to 20 of 29
    May 2016
    Hello! I think i'm having a problem with my car's alternator.when i start the engine i hear a hissing sound on the left side where the alternator is. But when the engine warms up, the sound decreases or disappears. I tried googling the problem but most say that the sound is constant.i recently changed my belts and had them adjusted and re-adjusted but the sound is still there.
    Mar 2013
    Maybe a vacume leak somewhere in the idle-up side kung malapit siya sa alternator. Pabago-bago ba sir ang idle?
    Mar 2013
    Kung alternator whining sound and constant nga
    May 2016
    Quote Originally Posted by joey36b View Post
    Thanks sa reply sir. Di naman po pabago-bago idle. And yung sound po is marinig sa start ng engine pero pag nagamit na halos wala na sound,minsan bumabalik hissing sound but di ganun kalakas.
    Mar 2013
    Mileage mo sir? Auto?
    Quote Originally Posted by iamnewhere View Post
    it would be nice to know what car we are talking about.
    but my very wild guess is, your idler bearing is about to die.
    Jul 2016
    Tangalin mo belt ng alternator, pag nawala ung hiss edi sa alternator nga and pa check mo na lang baka bearing...
    Mar 2013
    Magagandang idea na nasabi sa taas[emoji121]🏻️[emoji121]🏻️[emoji121]🏻️
    Aircon pulley, idler, alternator, water pump, power steering pump puro maybearing na pwede tumunog sila. Carbon brush pagmaikli minsan tumutunog din sa unang start, power steering pagkulang fluid maytunog din. Vacume canister ung sa emission maytunog pagstart at pagengine-off pagluma na. Fake na fanbelt pagmahigpit masyado ung dulas nya sa pagstart maytunog din hehe
    tongue-in-cheek...
    kapag herring sound, siguradong basag na bearing na.
    apologies... couldn't resist..
    Mar 2017
    Use a stethoscope (or improvise with a plastic tube) to localize the sound.
    May 2016
    Thank you sa mga reply and tips. It's an old pajero po 2000 fieldmaster with 75k mileage.2nd hand na po namin nakuha. May vault guage pag di pa nstart engine nasa 11v tapos pag napaandar unti unti na akyat sa 12v then dun na magstay.motolite excel yung battery but 9mos pa lang to. Tried to localize the sound using steth mukhang sa alternator nga galing. Mukhang di pwede ibyahe to.
    Mar 2013
    Hirap pa naman sumilip jan mataas na masikip pa hehe.
    Ano ba klase ng tunog sir? Grinding metal o hangin ang dating?may fieldmaster kasi na ang alternator mayvacuum pump sa likod baka ganon ang sainyo.
    May 2016
    Yes sir medyo masikip nga.tried pakinggan yung alternator with stethoscope, more on grinding pero mahina.pag naka andar makina medyo na ooverlap yung sound..di ko maroadtrip kasi baka bigla ako tumirik.matic pa naman.
    Mar 2013
    Kung grinding metal ang dating bearing kung medyo pino at mahina paubos na carbon brush malapit na tumama ung spring or copper wire sa armature. Isip ko lang yan sir hehe pacheck mo na lang. hangang charging pa siya pagawa mo na lang cheap lang bearing at carbon brush. Pagnasunog rectifier eh mahal.
    May 2016
    More on pino ang sound sir tapos pag medyo na warm up na engine mas humihina na siya. Di ko nga magamit kasi baka lalo masira alternator. Sa Monday ko pa mapa check kasi sa reys electrical ako magpacheck eh sa Monday pa sila bukas. Wala na kasi ako alam iba autoelectrical na maganda dito marikina hehe.
    Mar 2013
    Medyo mahal sa reys but sure ball naman gumawa
    Ako about 2 yrs ago nang nagloloko alternator ko ginawa ko pinabaklas ko sa suki kong electrician/mechanic sabay tinakbo ko sa yock's electrical shop sa edsa, qc. All the way from las pinas bro. Nakakatakot kasi tirikin sa gitna ng biyahe. Ayuz na ayuz naman kinalabasan ��
    siguro kung ako, ay tinakbo ko kay yock's, at kay yock's ko pinabaklas.
    no way na ko tatakbo ng kotse na may alternator na nagpaparamdam. nangyari na iyan sa akin during my gung-ho-didn't-know-any-better-younger-days...at dahil sa katangahan inabutan ako sa coastal road during my late evening drive home. doon ko unang naranasan talaga mag break into cold sweat
    clarification...
    did you have the alternator removed from the car, then drove that alternator-less-car to yock's?
Hissing alternator
