Results 41 to 50 of 63
- Jul 2011
- 262
July 6th, 2012 09:09 PM #41
July 6th, 2012 09:24 PM #42
- Jul 2010
- 570
July 6th, 2012 09:53 PM #43Baka masyado mababa idling rpm mo at kaya hindi masyado makargahan ng Alternator yun battery. Lalo na kung luma na ang battery. Kung below 800 rpm ay itaas mo ng 900 rpm. Dapat mas mataas ang charging voltage +13.5V.
Kung +12V lang galing sa Alternator ay hindi nito makargahan ang battery kasi pantay lang ang voltage nila.
Magpa install ka na rin ng Grounding Kit. Malaking tulong ito sa electrical ng lumang kotse. Dahil marumi na iyong mga terminals ng mga grounding wire at minsan under rated dahil sa mga dinagdag na mga load.
July 6th, 2012 10:03 PM #44
apologies for not being familiar with your car, does the alternator have a built in voltage regulator? if it does not have it built in, the voltage regulator must be in the PCM like some of the newer asian cars and all of the chrysler products. usually, in this case of the PCM housed voltage regulator, the cause is the electrical load sensor or the battery temperature sensor
- Jul 2011
- 262
July 7th, 2012 08:14 AM #45KIA pregio yung sasakyan ko, not sure kung meron US version.. try ko na i-google at nakakita naman ako ng mga diagram kaya lang not sure kung applicable sa sasakyan ko ...
dahil luma na sasakyan ko, advisable ba na magpainstall na lang ako ng separate new wires going to headlight at parklight?
para mapadali yung isolation and at the sametime eh ma-lessen ang factor ng wire resistance sa voltage drop kapag naka-on yung park light at headlight.
TIA
- Jul 2011
- 262
July 7th, 2012 08:44 AM #46thanks uli
not sure kung ilan ang rpm ko kase walang tachometer yung KIA pregio ko pero as i posted eh nasa 13.8V~14.1V ang output voltage ng alternator ko measured sa battery terminals while the engine running at idle at nakaswitch off lahat ng electricals.
bumababa lang yan kapag naka-on na yung parklight at headlight.
pero maski itaas ko yung rpm at basically tumataas din yung nasusukat na voltage pero once na nag-switch on ako ng parklight at headlight eh nagbababa pa din ng almost 0.8V~1V na sa palagay ko at base na rin sa ibang input/commet eh dapat hindi ganun
if magpapainstall ako ng grounding kit eh saan naman ito iinstall or saan ito iko-connect? pagkakaintindi ko yung body/chassis mismo eh ground na. I tried naman icheck continuity from battery negative terminals papunta sa lahat ng metal parts eh almost zero resistance naman.
meron bang possibility na hindi maganda grounding ng headlight at parklight ko kaya bumababa yung voltage kapag naka-on na?
TIA
- Jul 2011
- 262
July 7th, 2012 09:03 AM #47
July 7th, 2012 09:41 AM #48
dyan nga mahalaga yung sinasabi ko earlier na current draw test, hanap ka ng tech na pwede gumawa nito, voltage drop test is also one method. kung basic test lang, test mo mga suspect areas ng headlamps (since according to you dun bumabagsak ng todo). to give you a hint : check the headlamps ground (voltage drop test), check headlamp switch (visual lang makikita mo kung may signs ng nag iinit mga contacts, dapat tight ang contact) pag nakita mo ang culprit be sure the connections are tight and put some dielectric grease sa mga connectors.
- Jul 2011
- 262
July 7th, 2012 10:08 AM #49
July 7th, 2012 10:55 AM #50
dielectric grease para ma prevent ang corrosions sa mga electrical contacts like sa mga connectors
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
