Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 63
    Jul 2011
    #41
    hehehehe that's the distinction between the "mechanic" and the technician. having the electrical wiring diagram is a must if you are troubleshooting. it is comparable to being dropped in the middle of paris and told to find your way without a map. reading and interpreting the diagram, knowing the test points, knowing what to test at certain parts of the circuits and knowing the anatomy of your vehicle. this is the forensics part of being an auto technician
    i agree..
    kaya nga baka pede.. pasuyo nung basic circuitry ng parklight at headlight kagaya ng tanung ko sa previous kong post
    Feb 2009
    #42
    Quote Originally Posted by gtamp View Post
    i agree..
    does your car have a u.s. version? if it has i would be happy to share it with you. or, you can probably google the diagram
    Jul 2010
    #43
    Baka masyado mababa idling rpm mo at kaya hindi masyado makargahan ng Alternator yun battery. Lalo na kung luma na ang battery. Kung below 800 rpm ay itaas mo ng 900 rpm. Dapat mas mataas ang charging voltage +13.5V.
    Kung +12V lang galing sa Alternator ay hindi nito makargahan ang battery kasi pantay lang ang voltage nila.
    Magpa install ka na rin ng Grounding Kit. Malaking tulong ito sa electrical ng lumang kotse. Dahil marumi na iyong mga terminals ng mga grounding wire at minsan under rated dahil sa mga dinagdag na mga load.
    Feb 2009
    #44
    i agree..
    apologies for not being familiar with your car, does the alternator have a built in voltage regulator? if it does not have it built in, the voltage regulator must be in the PCM like some of the newer asian cars and all of the chrysler products. usually, in this case of the PCM housed voltage regulator, the cause is the electrical load sensor or the battery temperature sensor
    Jul 2011
    #45
    KIA pregio yung sasakyan ko, not sure kung meron US version.. try ko na i-google at nakakita naman ako ng mga diagram kaya lang not sure kung applicable sa sasakyan ko ...
    dahil luma na sasakyan ko, advisable ba na magpainstall na lang ako ng separate new wires going to headlight at parklight?
    para mapadali yung isolation and at the sametime eh ma-lessen ang factor ng wire resistance sa voltage drop kapag naka-on yung park light at headlight.
    TIA
    Jul 2011
    #46
    Quote Originally Posted by Chinoi View Post
    thanks uli
    not sure kung ilan ang rpm ko kase walang tachometer yung KIA pregio ko pero as i posted eh nasa 13.8V~14.1V ang output voltage ng alternator ko measured sa battery terminals while the engine running at idle at nakaswitch off lahat ng electricals.
    bumababa lang yan kapag naka-on na yung parklight at headlight.
    pero maski itaas ko yung rpm at basically tumataas din yung nasusukat na voltage pero once na nag-switch on ako ng parklight at headlight eh nagbababa pa din ng almost 0.8V~1V na sa palagay ko at base na rin sa ibang input/commet eh dapat hindi ganun
    if magpapainstall ako ng grounding kit eh saan naman ito iinstall or saan ito iko-connect? pagkakaintindi ko yung body/chassis mismo eh ground na. I tried naman icheck continuity from battery negative terminals papunta sa lahat ng metal parts eh almost zero resistance naman.
    meron bang possibility na hindi maganda grounding ng headlight at parklight ko kaya bumababa yung voltage kapag naka-on na?
    TIA
    Jul 2011
    #47
    not sure lang kung built in na. nagpalit ako ng alternator dahil yung nasusukat na voltage eh hindi na umabot ng 12V so hindi na nagkakarga ng maayus. ang pagkakatanda ko eh ichecheck daw yung voltage regulator at yung windings so cguro built in na
    #48
    dyan nga mahalaga yung sinasabi ko earlier na current draw test, hanap ka ng tech na pwede gumawa nito, voltage drop test is also one method. kung basic test lang, test mo mga suspect areas ng headlamps (since according to you dun bumabagsak ng todo). to give you a hint : check the headlamps ground (voltage drop test), check headlamp switch (visual lang makikita mo kung may signs ng nag iinit mga contacts, dapat tight ang contact) pag nakita mo ang culprit be sure the connections are tight and put some dielectric grease sa mga connectors.
    Jul 2011
    #49
    Quote Originally Posted by t2erns View Post
    thanks uli,
    yes, lahat naman ng input/comments eh tinatandaan ko. ..atleast now meron na akong konting idea kung anu ang ipapacheck ko
    anu yung dielectric grease? anu benefits nito sa mga connectors?
    #50
    dielectric grease para ma prevent ang corrosions sa mga electrical contacts like sa mga connectors
    Jul 2011
    #51
    thanks uli,
    dami ko natutunan..sana more inputs at comments pa
    TIA
    Jul 2011
    #52
    update lang...not sure if its good or hindi
    went to almost lahat ng autoshops malapit dito sa amin and halos lahat sila eh walang gustong magcheck ng wirings of my parking and headlight instead they recommend or cguro mas tama yung binebentahan ako ng "lighting harness" atleast daw eh kung magupgrade daw ako ng bulb ng headlight hindi ko na raw kailangan pa magupgrade ng wirings.
    to make the long story short, nagpainstall ako ng "lighting harness" kaya lang hindi nasolve yung problema na pagbaba ng voltage pero atleast hindi na 12.1~12.2V kapag naka-on lahat ng electricals..kundi nasa 12.4~12.6V na.
    if naka-switch on ang parking light lang eh halos hindi na bumaba. sa ilang beses ko check eh mga 0.1V lang ibinaba
    then kapag switch on yung headlight (hi & lo) bumababa na lang 0.4~0.5V
    hmmmm mukhang papadouble check ko na din alternator ko..
    #53
    If all accessories are turned on, and you're at 12.4V to 12.6V,- it is not that bad, bro.
    16.3K:shower:
    Jul 2011
    #54
    16.3K:shower:
    yes medyo kuntento na din ako sa ngayun at tumaas ng kaunti yung voltage. pero mas ok sana kung halos hindi bumababa or kung bumaba man eh less than 1V lng sana...
    during daytime na gamit eh ayus lang less than 1V lang binababa kase A/C at stereo lang naka-on.
    thanks talga ng madami sa lahat nag-input at comment ..
    Feb 2012
    #55
    mga paps ung sa liteace ko 13.6 pag naka idle tapos pag on headlight pati aircon bumababa na sa 12.1 tapos nanginginig na sa baba ng menor
    Jun 2011
    #56
    Quote Originally Posted by sotel View Post
    sir dagdag kau ground sa battery usually po pag mag edad na ang car mahina na ang ground, add din kay ng addl. wire galing alternator papunta sa battery..... or baka malapit na mag retire battery nyo....
    Feb 2012
    #57
    kaka palit ko lang ng battery.. dba dapat tataas ang idle pag aircon? sakin bumababa tapos nanginginig.
    80 amps na ung alternator ng liteace ko
    Feb 2012
    #58
    Quote Originally Posted by akosijepoii View Post
    try mu pasukat yung volts dapat nag lalaro sa 13 to 14,pag nka load kna ng aircon headlight etc dapat d babab sa 12v pag bumababa may prob alternator mu lalo na nka 110amperes na alternator kna..nway i owned a electrical shop here in sampaloc ska importer/wholesaler ako ng surplus alternator starter ska compressor..mdme ako nyang 110amperes na yan we sell it for 4500k marami pag pipilian
    sir saan banda sa sampaloc
    sir alam mo ba kila buddy electrical shop
    Feb 2012
    #59
    kila buddy ako nag papalit ng alternator baka sayo din kinuha
    Feb 2012
    #60
    deleted post
Bumababa ang voltage kapag naka-on parking/head light
