mga sir,
ask lang po ako ng expert/experienced opinion regarding sa pregio ko. Bumababa kase yung voltage kapag naka-on na yung parklight at headlight. from 13.8V to around 12.3V sometimes until 12.1V
Anu kaya ang nangyayari kung bakit bumababa? TIA
mga sir,
Your alternator cannot cope up with the amperage(current) requirement of your lights/accessories.
It is either inefficient now, in which case, it needs to be repaired. Or, not the right one, in which case, replace your alternator with the one with a higher amperage rating....
Or, check the wiring and the accessories,- they could be drawing much higher current than they're supposed to,- so the drop in the voltage.
16.1K:nerves:
sensya na po hindi ko pala na mention, yung pagbaba ng voltage eh kapag naka-idle and also just recently replaced the alternator from original of 75A to 110A (P6,000). hindi na kase nagkakarga kaya I decided na palitan na. kaya lang hindi ko naman sure kung 110A yung ipinalit basta sabi nila sa akin 110A yun. first time ko lang po kaseng magkaroon ng sasakyan kaya talagang wala akong alam. And then after replacement eh sabi ok na daw magkarga
anyways back sa bumababa na voltage, kapag ang aircon ang naka-on or yung stereo w/ subwoofer or yung fog light w/ separate switch eh hindi naman ganun kalaki yung binababa ng volatge from 13.8 to 13.4 or until 13.2 lang and palagay ko still enough para magkarga..ayon na rin sa mga nababasa ko dito
if wiring ang checheckin, panu po ang pagcheck? panu po ang basic na konenksyon or ng circuit ng parking light at headlight? kase sabi naka parallel lang daw ..tama ba?
salamats po uli..sana madami pang inputs/suggest
When your voltage drops to 12V, does it go up to 13.8V again or does it stay at 12V? If it goes up after a few seconds, I think thats normal. If it maintains at 12V then something is wrong.
check the grounds. check the current (ampere draw, voltage test is not always accurate)
yes it stay there during idle, then goes up kapag ni-rebolusyon. yes i think na there is something wrong kaya I decided to post it here to get more infos, ideas, inputs and suggestions kung anu/panu/bakit nangyayari yung ganun para bago ko ipagawa eh meron akong idea kung anu/panu dapat gagawin nung gagawa
panu kaya ang basic koneksyon nung parklight at headlight?
Well, with this we can rule out that you have a faulty alternator. An alternator does not give out a consistent amperes naman talaga.. it's an upward sloping in most cases. More RPM = more amperes. I would also note that you do not measure your voltage on a cold-start. Kasi talaga mababa yan the first few minutes. Mine stays at 12~V according to my voltmeter before rising to a consistent 13.8V
Unfortunately, I'm experienced about sa headlight amperes so can't help you there.
first to check is the battery ground, check kung mahigpit at may good contact. kailangan mo ng ammeter para masukat ang ampere draw. at idling and na load lahat electrical mo makikita mo kung ilang ampere (current) ang nagagamit, but you'll need a little advance knowledge sa electricity kung normal ang current draw and you can compare kung kaya ng alternator mo issupply ang load demand.
Wow! You have a 110A alternator pala e... More than enough iyan, dahil 80A should be more than enough capacity na.... Unless, it is not really a 110A alternator....
If you are reading 13V with your A/C and other accessories on,- then you should be okay.
Now, let's run through the other accessories:
Ano ang voltage reading with your park lights on?
Turn on your foglamps,- ano na ang voltage reading?
Turn on your headlights(low beam) - ano ang voltage reading?
Turn on your headlights(high beam) - ano ang voltage reading?
Put in your measurements and we can probably localize where the problem is....
16.1K:nerves:
thanks
so far evrytime check ko langis, coolant at fluid eh sabay ko namn nachecheck yung higpit ng mga terminals ng battery at mahigpit namn. wala akong ammeter so hindi ko macheck pero considering na hindi normal ang current draw, it is a cause po ba para bumaba yung voltage ko kapag naka on yung parklight at headlight ko?
from 75A to 110A yung alternator ko, then yung mga nadagdag lang namn eh aux. fan for radiator and main condenser, subwoofer, foglight, power window motor and cabin blower.
just wondering kase everytime lang na naka-on yung parking light at headlight saka halos 1V yung ibinababa ng voltage pero kapag hindi naka-on eh wala pang 0.5V ang ibinababa so kung naka-on lahat from 13.8V - (1V + 0.5V) = 12.3V which parang hindi enough to charge the battery during idle
from 13.8v~14.1V * idle - running for few minutes
switch on A/C = 13.3~13.5V
switch on fog lamp, stereo with subwoofer 13.0~13.3
switch on parklight 12.6~12.8V
switch on headlight low beam 12.3~12.6
then high beam 12.1~12.3
more or less ganyan ang read out
pero if I able to resolve yung pagbaba ng voltage kapag nakapark light at headlight eh good enough na sa akin para atleast yung minimum voltage requirement eh ma-meet para maganda ang charging eh
maraming salamats uli
Actually, for as long as the voltage measurement is >12V,- your battery is charging. Anyway, you're not idling all the time, so when you're rolling, the battery is charging correctly.
Please respond on the step by step measurement and hopefully, we can localize where the issue is....
Ano ba ang power rating ng iyong foglamps at headlights(low/high)?
16.1K:nerves:
When you're idling, you can probably just engage your headlights(low beam). No need to turn on your foglights... How's your voltage measurement here?
Also, the compressor cycles on/off,- how is the voltage measurement with the above condition when the compressor disengages?
16.1K:nerves:
