Results 11 to 20 of 82
August 13th, 2007 11:54 PM #11
yan ba yung aluminum face? madalas gamit sa old benz? kasi kung yun nga, madali ng sya masira pag nababasa.
don't tinker with the frequency magloloko yan. but if you really want to tinker with it, its that black glue-like thing near the word bosch. you'll have to remove it the you will see a screw inside which you can turn to adjust the tone.
and like Joey said put a relay, it needs a strong stable current.
August 14th, 2007 12:04 AM #12
any remedy kung medyo ngo ngo na yung sound ng europa? been using mine for 5 years ang pangit na ng tunog. should i try adjusting the frequency?
August 14th, 2007 12:17 AM #14
August 14th, 2007 12:22 AM #15
thanks peeps, sobrang loyalist ko kasi sa europa way (way way way)
back college pa, meron ako nakatabi 3 pairs sa bodega, matry nga yung wd40 trick na yan, gamit ko ngayon 2 pairs ng europa.
August 14th, 2007 01:23 AM #16
Originally Posted by augustus
August 14th, 2007 01:43 AM #17
Yeah you're right the standard Bosch ones are 335Hz and 420Hz for the low and high tones. Dapat pala Europa kinuha ko hehe oh well I'm back in the US...
I think the adjustment is only for "recalibrating" kapag wala na sa tono kasi I tried adjusting the new ones we got (standard Bosch for the Civic) and they're pretty much the same sound. Overadjusting resulted in a nullified effect nawala yung tunog ng isa (yung adjusted) kaya balik sa dati ayun bumalik. So I think you can't change the frequency of the tone di mo pwede pababain it's in the material I guess...
August 14th, 2007 02:01 AM #18
sa pagkaalala ko, not sure ah, nung install ko europa, both horn 300hz something yung low and high, di yata siya umabot ng 400hz. kakatapos ko lang lagyan ng wd 40 yung europa ko, pero parang kailangan kalasin kasi yung outer part lang ang nalagyan, which part ba dapat ma oil? should i remove the nut at the center para malagyan yung loob?
August 14th, 2007 04:01 AM #19
straighsix, tama ka, it should be 300hz and 375hz. my mistake, na sanay na kasi tayo sa computer speak na puro Mhz and GHz
promdiboy, sa palagay ko worse comes to worst, you might want to try opening it up to see if something can be done on the inside.
yun na rin ang gagawin ko if all else fails before buying a new one.
August 14th, 2007 04:06 AM #20
augustus, di ko mabuksan grill, lilinisin ko nga sana, naka paikot yung clip, di mo sabay sabay matulak.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
