Results 1 to 8 of 8
    Hi mga peeps, has anyone tried using a similar device?
    Found it very affordable, price range only PhP 800 to around PhP 2000. There are many sellers in OLX.
    Some Features:
    Depending on the application,
    the following features may be available through a smart phone interface:
    Check Engine Diagnostics
    Real-time gauges
    Fuel Efficiency and MPG
    Engine Sensors
    Customizable Dashboard
    Real-time Dyno
    Data Logging
    GPS Track Mapping
    Skid Pad
    Would there be issues with the vehicle warranty if installed? How about accuracy of results?
    Please indicate vehicle type and model for those who have tried it. This will be useful for us who might find this devise interesting and worth having. Thanks
    Attached Thumbnails Attached Thumbnails car-auto-mini-v1-5-interface-bluetooth-obd2-ii-diagnostic-interface-scanner-9012-1635541-1-produ.jpg   elm327bt_torque.jpg
    Jul 2012
    also interested if it will work in my jazz gd...
    Jun 2015
    Works with Mirage 2015 hatchback. Pretty sure it'll work on Mirage G4 as well.
    sent via Tapatalk
    Quote Originally Posted by L22 View Post
    Some Features:
    Real-time gauges
    Engine Sensors
    Real-time Dyno
    Data Logging
    GPS Track Mapping
    Skid Pad
    Yung akin nabili ko sa Lazada, Vgate ang tatak (last year ko pa nabili pero wala na yata ngayon). Pare-pareho naman ang mga yan na ELM 327 chips. Ok naman siya for scanning ECU faults and monitoring engine parameters (boost, temps, speed, rpm) using Torque in my Sorento.
    Jul 2012
    may nag try na po ba nito sa jazz gd3? (2005 model)
    Dec 2025
    Yes it's worth it.
    Jan 2026
    It's worth it to have one
    Jan 2010
    I have one and it works well even on EV's and hybrids (even shows battery stats). The one I got is the Vgate iCar Pro 2S OBD2 was just under 1k thanks to vouchers on Shopee.
    https://shopee.ph/%E3%80%90for-Hybri...67.26603397677
Bluetooth OBD2 Diagnostic Scanner - worth having?
