i can't remember na when was the last time i replaced the battery ng lumang vios ko (2006 model). pero mas longer ang ang life span ng battery ng vios ko kesa sa montero considering na gamit na gamit at daily drive din dahil panghatid/sundo sa daughter ko to school which is mga 30-45 mins from home. nakadalawang palit na ako sa montero sa vios yun pa rin. my SL grandia (bought Nov 2014) di pa rin nagpapalit battery ok pa naman...
Diesels have pre-heaters. Even if its direct injection, CRDi, DDi, EGTV, etc.
They still have pre-heaters, which equate to battery juice being used up.
I have a Strada 4D56. When I turn on the engine, the heater (idiot) light just flashes then turns off. Basically this will tell you that the engine is ready to start, di ba? What others would not know is that the heater relay is still in the "on" position. And this relay dis-engages a good 5-10 seconds after the heater light went off!
I don't know if its the same with a Montero, but upon turning my engine on, I hear a slight "knock" ... that's the heater relay energizing. It will continue to energize, way after the heater light went off. In about 10 seconds, the heater relay will dis-engage, (you will hear it "knock: again).
That's when I start my engine.
