Results 1 to 6 of 6
- Jun 2007
- 1,161
December 3rd, 2011 03:51 PM #1good day po....
kapag umuulan ng malakas at nadadaanan ko yung may konting tubig o baha (hindi naman mataas), bigla pong umiilaw yung battery indicator ng car ko. ang ginagawa ko, pinapatay ko yung aircon at nawawala yung ilaw ng battery indicator.
ano po kaya ang posibleng sira? tama po ba nag lagyan ko ng grounding papuntang makina?
yung car ko nga po pala ay nissan sentra 95 series 3.
maraming salamat in advance.
December 5th, 2011 12:41 PM #2
your carbon brushes might have worn out and the carbon dust is settling around the slip rings and the voltage regulator. when there is such accumulated carbon dust, it is prone to absorbing moisture and give you a drain to the battery aside from the intermittent no charge or insufficient charge condition. have the alternator serviced or have the brushes replaced
February 14th, 2012 02:12 PM #4
OT:
"I was driving earlier this morning and notices that the tail lamp indicator flashes in the dashboard whenever I step on the brake. The brake pedal now acts like a switch to activate it whenever I step on it. I also hear a 'tik' sound whenver I step on the brake probably signalling the tail lamp switch. Might be a case of a short in the circuit? what should I do? "
repost from Innova thread. ano usual na culprit sa ganitong problema bro? sana light bulb lang nga nag short.
February 14th, 2012 02:57 PM #5
[QUOTE=Retz;1874800]OT:
sir na check nyo na po ba kung ok lahat ng bulbs nyo sa likod? nagpalit po ba kayo ng bulbs recently?, most common problem po eh busted bulbs or wrong bulb installed...............................
February 14th, 2012 03:14 PM #6
Kwento ng katrabaho ko, meron daw sya officemate dati na Italiano na tinanong daw bakit...
Traffic!
