Results 1 to 6 of 6
    Nov 2004
    Pa recommend naman on how to fix and where preferrably south area.
    My ride is an Altis auto. 2003 with an airbag
    Previously sometimes the horn will function and not function.
    Yesterday it has no sound at all up until today.
    thanks
    Jan 2011
    remove the terminal socket from your horn, kuha ka ng electrical wire, try mo iderekta sa battery kung ok naman siya at tumutunog, baka yung wiring ang may deffect
    Jun 2005
    if its stock, just replace it. any car accessory shop has that.
    Feb 2011
    check mo yung wirings..baka nag loose lang or poor contacts, liyahin mo yung mga terminals..
    Aug 2008
    sir baka po yung clock spring sa likod ng steering wheel ang may problem para po syang ribbon wire dun po dumadaan lahat ng kuryente papuntang manibela, horn, airbag trigger, etc.
    Feb 2009
    Quote Originally Posted by danteps View Post
    check your fuses first. then, check if there is sufficient ground and power to the horn connectors. measure the voltage across the negative and positive terminals. specially, do not probe, jumper or disconnect the wires that are color coded yellow or harnesses color coded yellow lest your airbag deploys unintentionally unless the srs or airbag system had been disarmed. follow service precautions to avoid accidental deployment, damage to the vehicle or injury to yourself.
Horn Problem : No horn sound Altis 2003 with air bag
