Bumalik ako sa mardenrey, ok naman daw alternator ko, tuyo naman daw ying ilalim, mukhang di naman daw natuluaan ng powersteering fluid and malakas naman daw karga (14.5v).
the measurement should include current (amperage) at the battery terminals. measure at the positive cable and again measure at the negative cable closest to the battery. if there is a considerable resistance at any connection, the voltage reading may indicate 14.5 volts but the current was limited by the resistance. if the voltage is as what you insinuated but the current is low going to the battery that is less than 60% SOC (state of charge), there is a high resistance in the charging circuit.
