Results 1 to 4 of 4
- Aug 2013
- 11
February 9th, 2015 02:28 PM #1Hi Sirs, my ride is a Honda Odyssey '95. For the past 2 weeks, sometimes the battery and catalytic converter warning lights will go on at the same time and off after a few seconds. So far it happens when I shift from park to reverse or drive. After it goes off, it won't indicate again while driving the rest of the way. Once I start the engine again, it will show again also with the same conditions as mentioned above.
Any ideas?
Thanks.
February 9th, 2015 09:49 PM #2
Check your system voltage with the warning lights turn on or off. Sounds like your battery is nearing its demise
- Aug 2013
- 11
February 10th, 2015 09:02 PM #3Thanks Jick. Will do that. Although last time I checked, the battery still has a green indicator.
February 10th, 2015 09:43 PM #4
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
