Results 11 to 17 of 17
- 54,293
March 2nd, 2014 12:00 PM #11
- Nov 2009
- 3,509
March 2nd, 2014 12:12 PM #12Nagpalit sya dati ng battery at nag crank, so he assumes not a starter problem.. Turns out, intermittent starting due to worn brush of starter. Anyway, doon din talaga direction ituturo ng mekaniko(ignition/ starting system) kung na-test na OK ang battery & charging system.
Glad ur ride is back to normal TS.
- Sep 2011
- 626
July 10th, 2014 09:01 AM #13Sirs goodmorning po. Our ride is a 2009 MS. For the past 2 days hirap siya mag start. Nung unang araw, nagpajump start ako sa vios. Nung second day, nagpajump start ako sa fortuner pero ayaw parin so we decided to switch batts para maistart ko lang si MS. I also checked the battery voltage and cleaned the contacts and had a shop assess it. Nagkakarga naman si alternator. The shop gave me a warranty sa battery namin and for the meantime gave us a service battery which upon connecting, nag 1click start si MS.
Last night, coming from a drive using the service battery, kapag pinatay ko engine and let it sit for a couple of minutes (5mins) and try to start it again, ayaw na mag start. Mag redondo lang siya and after a few tries, mag click nalang. Called my dad to jump start it and after 5 mins nag start na siya. This morning, i checked the battery wires and its warm to touch. Im somewhat sure that something is draining the battery. All electricals are original pa.
Ano po possible issues nito sir?
July 10th, 2014 09:19 AM #14
- Sep 2011
- 626
July 10th, 2014 09:31 AM #15Thank you for your reply sir.
Yung alternator po ba naka connect palagi sa battery? Yung starter kasi mag coconnect lang siya kapag nag ignition ka. Kapag nag run na engine, mag disconnect na siya.
Nung first time po nangyari na ayaw niya mag start, nasa covered parking lot po ako and dry naman po yung car.
July 10th, 2014 09:43 AM #16
the alternator is always connected, the output terminal BAT is connected directly to the battery positive through the highest rating fuse in a car. the other wire/s are connected but are interrupted or connected by the ignition switch. if the alternator brushes are worn out, the carbon dust accumulates inside the alternator and is a possible cause for an internal unintentional connection to ground.
- Sep 2011
- 626
July 10th, 2014 10:03 AM #17Ah sige sir. Salamat po. I also watched a video on youtube to find potential shorts. Ill try to do it paguwi.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
