AnO kaya nangyari bakit hindi pantay ilaw headlight ko.parang parklight lng isa.gumagana naman parang flashlight lang.salamat
sounds like poor electrical connection. check them all, including the socket itself. sometimes, the socket is so old, it doesn't offer good electrical connection anymore.
check mo din yung bulb. baka pang-24 volts ... heh heh..
ah... i was refering to bulbs, not sealed beam headlights. looking at the threadstarter's handle, i assumed his headlight uses bulbs and not sealed beams. in surplus stores, one occasionally encounters bulbs from other vehicles...24 volts.. i know, because i experienced it years ago...
but if he means, the headlight was bright before, and now dim, then i believe it's a problem of electrical connection..
i hope that clarifies things.
cheers.
pahabol: Heeey! the threadstarter is the liteace guy from the other thread! so, is your liteace sealed beam rectangular headlight, or bulb-type?
hello,bulb type po headlight liteace ko.tama ka dati pareho liwanag both headlights pero kagabi bgla nag dim isa.ipapatsek ko nga sa elektrikal shop baka sa wiring nga ba problema.salamat
bossing.. subukan mong ikaw na lang muna ang mag-troubleshoot. konting sakit sa katawan at dumi sa braso't kamay lang yan. if you have a liteace owner's manual, it may be easier. look up how to replace the headlight bulb.ang hinala ko, dirty electrical contacts between the bulb and the bulb socket..
good luck.
pardon my over thirty years of servicing cars and trucks more than twenty of which simultaneous with teaching but i have not seen 24 volt vehicle lights yet.
many years ago, when our automotive budget was near-non-existent, my brother and i would go to surplus shops for "parts". we were always happily surprised at the variety of items on sale there.. but our purchasing power was severely limited by our wallets. anyway, we got this bulb because our car needed a replacement bulb. we installed it, but were dismayed when it only glowed weakly. we did the usual electrical troubleshoot, to no avail. then we got the bulb out and examined it. on the metal base, was "24 volts".. i suppose, some extraordinary (military? aircraft?) ware came to get mixed with the civilian parts..
this was in the late 70s to early 80s... we would pool our wallets' contents to buy an item, making sure we still had enough for pamasahe pa-uwi..
this thread brought back fond memories.. i love my brother.. the experiences we shared..
have the same problem with my car once. kulang lang sa ground yun isang headlight kaya kulang sa lakas ng ilaw. hope it helps
