AnO kaya nangyari bakit hindi pantay ilaw headlight ko.parang parklight lng isa.gumagana naman parang flashlight lang.salamat
sounds like poor electrical connection. check them all, including the socket itself. sometimes, the socket is so old, it doesn't offer good electrical connection anymore.
check mo din yung bulb. baka pang-24 volts ... heh heh..
ah... i was refering to bulbs, not sealed beam headlights. looking at the threadstarter's handle, i assumed his headlight uses bulbs and not sealed beams. in surplus stores, one occasionally encounters bulbs from other vehicles...24 volts.. i know, because i experienced it years ago...
but if he means, the headlight was bright before, and now dim, then i believe it's a problem of electrical connection..
i hope that clarifies things.
cheers.
pahabol: Heeey! the threadstarter is the liteace guy from the other thread! so, is your liteace sealed beam rectangular headlight, or bulb-type?
hello,bulb type po headlight liteace ko.tama ka dati pareho liwanag both headlights pero kagabi bgla nag dim isa.ipapatsek ko nga sa elektrikal shop baka sa wiring nga ba problema.salamat
