Results 1 to 14 of 14
    Apr 2009
    hi fellow tsikoteers..
    Patulong kasi im not familiar.. meron bang digital na ampere gauge that you
    can put in your dashboard? para makikita kung maayos charging and battery.
    ang nakikita ko kasi sa mga jeepneys and old vehicles yung typical amp gauge na pumapalo lang siya kung ni rev.
    Quote Originally Posted by anthon05 View Post
    meron. just checkout car accessory shops.
    Apr 2009
    ok i will look around this coming weekend. curious din ako kung
    accurate and kung mganda lagay sa dashboard.
    thanks
    i've seen a digital voltage meter yesterday at Banawe... plug mo lang sa car cigarette lighter... it's around Php900 petot... i forgot name of the shop
    Apr 2009
    nagtanong ako sa concorde last weekend, nagulat ako sa price around 2500.00 sobrang mahal maganda sana.
    maghanap na lang ako sa mga auto supply. magtanong kaya ako sa cDR king... saan shop mo nakita? accurate kaya kung sa car lighter ikabit?
    d ba dapat sa battery na?
    sino nakagamit na?
    thanks
    i have a digital voltmeter kaso direct sa battery pag nag check ka,very useful to test kung weak yung alternator mo or yun battery.pang iwas loko sa mga sira ulo electrician.
    Apr 2009
    accurate kaya yung voltmeter na kinakabit sa lighter? and i'm looking for a
    gauge that i can install sa dashboard. para even when travelling ma view ko from time to time.
    thanks
    thanks
    Automotive voltmeters have two kinds. Analog and digital.
    You can install these on your dashboard either as a pod-style or cutting a hole in a blank area and installing it there.
    Apr 2009
    hi ghosthunter.. i like yung pics na post mo. where can i buy? and
    around how much?
    Thanks
    ok na rin yung sa lighter plug lang nilalagay. been using it for almost 2 years and it works fine. kabit lang sa lighter then ok na. pwede mo rin i pang test sa ibang kotse. tanong ka sa mga audio shops, sila usually nagbebenta ng mga ganon.
    ganito yung gamit ko.
    http://s6.invisionfree.com/cabspeed/ar/t71.htm
    Apr 2009
    hi nakabili na ako last weekend. 850 pesos red digits. yun nga lang wala siya
    brand, its almost the same sa picture mo. 675 lang pala dati.
    hindi na ako naka canvass or look for ibang design mahirap kasi magpark sa banawe unang store na natanungan ko, buy na. very plain lang itsura.
    meter reading ko. if d pa start engine 12.33 to 12.5v ..engine running 13.88 if open na AC and headlights around 13.40v.. ayos pa ba batt and alternator ko?
    thanks
    May 2009
    ok na ok pa charging system mo boss. kapag bumaba ng 12V na umaandar at walang naka-on na accesory like a/c, radio, etc. e either alternator or battery na ang problema. mas mababa pa nga readings sa pipip ko e. gnagamit ko lang e yung multitester.
    thanks
    Apr 2009
    ang question ko accurate kaya itong 'lighter' voltmeter? like yung ginagamit if sa battery connect?
    nakikita ko kasi mga auto electrical sa battery sila connect yung tester nila.
    Jan 2009
    If you're going to buy one, bring a known good multi-tester and use it to compare the output values to the voltmeter. It's hard to say if the voltmeter you're going to buy is accurate or not without doing this comparison test, since those voltmeters are mass-produced and are expected to be not as accurate as a good multi-tester.
    FWIW, I use the ScanGaugeII to display or check the battery voltage.
Amp or Voltmeter gauge na Digital?
