Results 11 to 14 of 14
- Apr 2009
- 533
November 3rd, 2009 10:00 AM #11hi nakabili na ako last weekend. 850 pesos red digits. yun nga lang wala siya
brand, its almost the same sa picture mo. 675 lang pala dati.
hindi na ako naka canvass or look for ibang design mahirap kasi magpark sa banawe unang store na natanungan ko, buy na. very plain lang itsura.
meter reading ko. if d pa start engine 12.33 to 12.5v ..engine running 13.88 if open na AC and headlights around 13.40v.. ayos pa ba batt and alternator ko?
thanks
November 4th, 2009 05:17 PM #12
- Apr 2009
- 533
November 4th, 2009 05:47 PM #13ang question ko accurate kaya itong 'lighter' voltmeter? like yung ginagamit if sa battery connect?
nakikita ko kasi mga auto electrical sa battery sila connect yung tester nila.
November 4th, 2009 06:32 PM #14
If you're going to buy one, bring a known good multi-tester and use it to compare the output values to the voltmeter. It's hard to say if the voltmeter you're going to buy is accurate or not without doing this comparison test, since those voltmeters are mass-produced and are expected to be not as accurate as a good multi-tester.
FWIW, I use the ScanGaugeII to display or check the battery voltage.
samin doc sinasabihan kami "mag nilay nilay" - be quiet. Bawal magsaya (common sense) and music or...
Traffic!
