Page 125 of 229 FirstFirst ... 2575115121122123124125126127128129135175225 ... LastLast
Results 1,241 to 1,250 of 2282
    #1241
    pag nasa 11.9 volts ayon sa volt meter habang hindi naka-start ang kotse ( nasa acc iyong ignition) kelangan ko ba pa-recharge? naiwan naka bukas kasi iyong led trunk light madalas habang nasa paint shop pag repair ng ilang body panels. pero wala naman problema sa starting siya
    just over a year old iyong 1sm hi-life
    the battery will be recharged back to normal, once the engine is started and the alternator kicks in.
    maliban na lang, kung nasira ang baterya dahil sa prolonged discharge. in which case, its remaining useful lifespan will be shortened. but you will know this, po. one morning in the near future, you will experience hesitation or even complete failure at starting.
    i have a local, basic, no-frills battery charger at home. 2K yata or so ang presyo noon. i bought it when i acquired an AT car.
    #1242
    ^ haven't tried using a battery charger. safe ba siya? kelangan ba ibaba ang battery kapag charge?
    i checked out the ones being sold at olx kanina. are they any good bro?
    Aug 2012
    #1243
    11.90V is approx. 40% battery power. Nag-start ba engine? If not, then need i-charge ang battery. If yes, no worries. Mag-charge ulit ang battery when you drive the car na.
    Sent from my D5833 using Tapatalk
    Aug 2012
    #1244
    I use automatic, smart battery charger. Can leave connected to car battery for extended time. No need to remove battery from the car. It switches to trickle charge mode once battery is full.
    #1245
    i have electrical background. that is why i do not fear using battery chargers. but today's chargers are oh-so-user friendly.. if one knows how to read and is not color blind, one should have no problems using one. and no, the battery does not have to be removed from the car, nor any of its connections removed, either. the charger's cables are easily clipped into place. a common problem, however, is the electrical socket in the garage.. sometimes, it is so far from the engine bay, one has to look for a long extension cable to connect to house current and power the charger.
    i use the charger only so's i can start the car (15-30 minutes only. times may vary, depending on the charger's capacity.).
    after starting it, my next stop would be the battery store, which, happily, is near the workplace.
    with today's technology, when my battery has problems starting my car in the morning, it means that battery is dying. hence the trip to the store immediately afterward. the battery guys check the battery and charging system of the car, to make sure it is battery failure and not something else.
    Jul 2014
    #1246
    You might find this article informative. Find the state of charge portion. Battery Basics: A Layman's Guide to Batte | BatteryStuff Articles
    I'm using the DHC 5Amp SC5E automatic battery charger. DHC Charger - Tire Center Philippines
    #1247
    Quote Originally Posted by Mask Rider Blac View Post
    now, when was the last time i saw a densitometer?
    Aug 2012
    #1248
    I recommend using in-car voltmeters para pwede ma-monitor ang battery power when engine off and engine on. This one is multi-function. It also serves as thermometer and USB charger.
    #1249
    Quote Originally Posted by red_one View Post
    uy!
    magkano, at san makakakuha?
    gusto ko.
    sa ngayon kasi, ozone generator lang ang naka-suksok doon.
    Aug 2012
    #1250
    uy!
    gusto ko.
    P600 from OLX or Facebook.
    D3 Technologies | Facebook
Amaron battery
