Results 1,241 to 1,250 of 2282
- 54,225
July 29th, 2016 10:42 AM #1241the battery will be recharged back to normal, once the engine is started and the alternator kicks in.
maliban na lang, kung nasira ang baterya dahil sa prolonged discharge. in which case, its remaining useful lifespan will be shortened. but you will know this, po. one morning in the near future, you will experience hesitation or even complete failure at starting.
i have a local, basic, no-frills battery charger at home. 2K yata or so ang presyo noon. i bought it when i acquired an AT car.Last edited by dr. d; July 29th, 2016 at 11:28 AM.
July 29th, 2016 11:00 AM #1242
^ haven't tried using a battery charger. safe ba siya? kelangan ba ibaba ang battery kapag charge?
i checked out the ones being sold at olx kanina. are they any good bro?
- Aug 2012
- 2,767
July 29th, 2016 11:02 AM #1243
- Aug 2012
- 2,767
July 29th, 2016 11:05 AM #1244
- 54,225
July 29th, 2016 11:11 AM #1245i have electrical background. that is why i do not fear using battery chargers. but today's chargers are oh-so-user friendly.. if one knows how to read and is not color blind, one should have no problems using one. and no, the battery does not have to be removed from the car, nor any of its connections removed, either. the charger's cables are easily clipped into place. a common problem, however, is the electrical socket in the garage.. sometimes, it is so far from the engine bay, one has to look for a long extension cable to connect to house current and power the charger.
i use the charger only so's i can start the car (15-30 minutes only. times may vary, depending on the charger's capacity.).
after starting it, my next stop would be the battery store, which, happily, is near the workplace.
with today's technology, when my battery has problems starting my car in the morning, it means that battery is dying. hence the trip to the store immediately afterward. the battery guys check the battery and charging system of the car, to make sure it is battery failure and not something else.Last edited by dr. d; July 29th, 2016 at 11:22 AM.
July 29th, 2016 11:50 AM #1246
You might find this article informative. Find the state of charge portion. Battery Basics: A Layman's Guide to Batte | BatteryStuff Articles
I'm using the DHC 5Amp SC5E automatic battery charger. DHC Charger - Tire Center Philippines
- 54,225
July 29th, 2016 11:56 AM #1247
- Aug 2012
- 2,767
July 29th, 2016 11:58 AM #1248I recommend using in-car voltmeters para pwede ma-monitor ang battery power when engine off and engine on. This one is multi-function. It also serves as thermometer and USB charger.
Sent from my D5833 using Tapatalk
- 54,225
- Aug 2012
- 2,767
July 29th, 2016 12:07 PM #1250P600 from OLX or Facebook.
D3 Technologies | Facebook
Mas ok yung may easy access na cap. My Panasonic battery with i-stop (most of the time I missed to...
