Results 1 to 6 of 6
    Jun 2010
    may kunting katanungan lang po ako mga sir. tungkol sa alternator ng van ko. mitsu l300 diesel van. yung isang terminal sa alternator, hindi nakaconnect.
    20130612_075021 by franmarkdancel, on Flickr
    yung connector po na may nut.yung katabi ng wire na may electric tape. checked the voltage on my battery, 12.6, even when running. di po ba talaga nakaconnect yun mga sir?
    Oct 2011
    Sir, not sure with the wirings but the moment na hindi umander ung alternator mo lalabas na ung battery sign sa dashboard mo and afaik nasa 13+V pag ni measure mo voltage kapag kumakarga alternator.
    Jun 2010
    yun din ang alam ko, 13+v dapat. pero di naman lumalabas/umiilaw yung indicator sa dashboard so medyo nalilito ako. try to go to electrician today,sana bukas sila,holiday pa naman. i DIY ko nalang sana kung may nakakaalam sa connection.hehe
    Oct 2011
    tska sir malalaman mo agad pag hindi na umaander alternator or hindi nag ch-charge. hihna ung bosina mo tska ung mga ilaw, pag namatay na makina mo hindi mo na yan ma start drain na battery mo.
    Jun 2010
    yun ang iniiwasan ko mangyari sir. mahirap maiwan sa kalsada.hehe
    Feb 2009
    Quote Originally Posted by fmark View Post
    if it is insulated from ground, it is the positive output towards the positive battery terminal of the battery. if it is not isolated/insulated, it is a dedicated ground for the alternator
alternator question.
