charging should be at least 14v at idle without load .
batt light in your cluster means something's wrong within your charging system . possible troubles are ; carbon brushes worn - out , rotor , stator , voltage regulator or the rectifier assy. assuming that your wires are OK , and the alternator is turning at required RPM .
