Results 1 to 9 of 9
    Sep 2013
    honda/lxi /1997
    hi mga sir newbie lng po ako dito ask ko lng po nasira po un alternator ng kotse ko and ang sbi ic regulator daw un sira..san po ba nkkbili ? and ok lng po ba pag surpplus un nabili ko..add ko lng po bigla ng overheat un kotse ko and un indicator sa panel hinde na ng off..
    Jun 2005
    bili ka nlng buong surplus. less headache
    Sent from my Thrill 430x using Tapatalk 2
    some of the well-stocked alternator repair shops might have the IC you need.. ask around.
    there's this shop along pedro gil, between benitez st and san marcelino.. near paco market.
    just the IC versus entire surplus alternator... ? ask for price first, then decide.
    Sep 2013
    slamat po sa feedback...
    Mga sir sbi po kase ng electrician na tumingin mganda pa raw un loob ng alternator ko..ang inaalala ko po ay kung maga
    ging mganda prin un performance pag ang pinalitan ko lng eh un IC.
    Quote Originally Posted by erick14 View Post
    that is why some will suggest to get an entire alternator replacement na lang..
    but if you ask me, i think replacing the IC alone (kung yun nga ang problema) will restore your alternator just fine.
    for all we know, that surplus alternator came from someone just like you, and the repairman just replaced the IC, too..
    Jul 2010
    Dalhin mo na lang yun sirang ic voltage regulator as sample para tama ang mabili mo.
    Jul 2013
    Quote Originally Posted by Chinoi View Post
    Isa sa mga mahirap palitan na parte ay ang ic ng alternator. This is bcause the ic placement is a compromise alternative; regulators should have ample heat sinking. I had devised a way to replace ANY ic with an outboard module with large heatsink. The alternator should be totally disassembled and some procedures to be performed first. Of course, this process should only be done by an electrician/technician who understands the intricacies of voltage regulation.
    The universal type module contain parts which are readilily available in raon. It can replace ANY ic for 6/12/24v and the charging current is adjustable for precise charging of the battery. E.G., for 12 car batteries, the charging current should not be over 25-30amps and the idle charge should be around 5amps.
    Actually, this is another invention which we applied at IPO in 2010 to replace ANY ic with ANY voltage. If someone who has experience in voltage regulation circuits is interested, send a message thru my inbox for details. Sorry, I dont do the repairs, I will only give instructions upon request.
    With this universal ic module, walang alternator ang mai-junk; lahat pwedeng ayusin.
    Jul 2010
    Meron ako nakatabi na sirang alternator para sa Lancer Itlog. Walang nakasulat na with Voltage IC Regulator. Yun ipinalit ko ngayun ay may nakasulat na with Voltage IC Regulator.
    Mukhang pwede ko na pakialaman yun sirang alternator. Mas mataas kasi capacity nito.
    Sep 2013
    Mga sir maraming slamat po sa mag inputs nyo ok na po c honda i did change the IC it cost me 1,100 with labor..ingat kayo lage
alternator ic regulator
