Results 1 to 10 of 14
July 6th, 2010 04:33 PM #1
Mga sir, patulong lang. Meron ako second hand na owner type jeep. Gusto ko lang sa sana malaman ang mga ito:
- How to know/check alternator's and battery's rating/capacity?
- What tag or label to look for?
- In case no more label or tag, ano ang iba pang paraan para macheck?
At ano pa ang pwede kong idagdag na mga accessories.(e.g. lights, carstereo, etc.)
Mahirap na kasi kapag hindi aware tapos magkaproblema sa kalsada.
Cguro tama naman yung concept na ito na alternator ang mas mataas dapat ang rating which must be enough to charge battery at operating condition without getting drained:
Alternator rating > Battery rating > Load
maganda na rin malaman ito at maapply kapag may kotse na ako.
maraming salamat.
July 7th, 2010 08:07 PM #2
most of starting/charging systems setup are within +/- 15 % of the starting system. for example toyota camry 2.4 liter engine uses 1.4 kw starter motor (1400w/12 v= 117 amps, the alternator is 100amps. the battery for the setup is 100amps X 6= 600 cold cranking amps battery. to determine your total current load, run all electrical loads like headlight on high beam, tail lights, blower motor, wipers and rear window defogger while measuring the current using an inductive pickup type ammeter. the loads should not equal to nor exceed the current demand of the starter
July 21st, 2010 05:14 PM #3
Bossing, hindi ko makita/malaman ang rating ng alternator ko eh. Paano ko pa kaya yun malalaman?
Saan makikita?
July 21st, 2010 07:25 PM #4
July 22nd, 2010 09:54 AM #6
July 26th, 2010 11:30 AM #7
eto lang ang nakita ko sa makina..
toyota 4K 1005381
ano mga bossing ibig sabihin nyan?
tapos sa alternator eh parang ganito:
..27020 11021 (nippondenso)
hindi na kasi makita ng maayos eh masyado luma..
(currently searching sa google ng nippon denso, bigo pa lang)
kung sakali may idea kayo...
sana may makatulong..
salamat....
- Sep 2008
- 737
July 26th, 2010 09:26 PM #8kung 4k at orig pa ang alternator. 15 amps yan. nga new cars nagyon na sa 60 amps na ang capacity. but dont worry. madami piyesa. kahit 60 amps ang ikabit mo pwd yan. kahit anong battery size pwd yab basta 12v. the bigger battery size the higher ampere rating.
July 26th, 2010 10:00 PM #9
THE AUTO SPECIALIST
- Mar 2006
- 607
July 27th, 2010 09:10 AM #10sa 4k engines alt rating nila 45A int reg or ext reg pareho lang
batt rating 500 A
CCA 400A
sa battery pwede na ang honda civic 90's model
ok din ang batt para sa 90s corollas
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
