Recently, itinirik ako ng aking old reliable Lancer Boxtype sa gitna ng South Luzon Expressway, the culprit: dead battery!!! Pina-check ko sa nearest Petron station then they said that the alternator is no longer charging that's why my battery was drained. So go ako sa aking trusted electrician and then they changed the IC assembly of my alternator and my old reliable Lancer Boxtype runs again but recently i discovered that pag gabi when lahat nakabukas (headlights, a/c, sound system) pag bumusina ako, PAOS!!! Pag umaga naman ok lang malakas siya.
Trying charging your batt first. Baka drain na o kailangan ng palitan. Utmost 2 yrs ang life ng batt. Nung pinalitan yung IC (voltage regulator), ganun din ba dati ang pinalit? Try to found out kung pinalitan ng iba baka mas mataas na ampere rating ang pinalit. Check mo din kung may mga wires na grounded (open wires touching the chassis/body and engine). ;)
Check the carb idle-up solenoid. Baka kailangang itaas yung idling para macompensate yung current load ng mga ilaw, busina, stereo, aircon, etc. ;)
Magpalagay ka ng voltmeter para sure. Pag umapak ka ng preno while at idle then bumaba ang voltage, I guess di na naayos talaga ang alternator mo. Or pwede rin ampmeter to check if your alternator is supply the correct power your vehicle needs. And from previous experience, twice ma-discharge yung battery mo and it's out. You'd have to change it for a new one.
