Results 1 to 10 of 11
April 11th, 2014 08:33 AM #1
this thread is in reference to:
http://tsikot.com/forums/toyota-cars...14/?highlight=
http://tsikot.com/forums/electricals...54/?highlight=
http://tsikot.com/forums/engine-fuel...99/?highlight=
http://tsikot.com/forums/electricals...22/?highlight=
1992 corolla, 4af engine carb-type
engine top overhaul done dec. 2013
distributor replaced feb. 2014
alternator upgraded from 65amps to 90amps april 2014
my current issue is, though not always but on some occasions, while im driving all of a sudden, the engine dies out and all electricals except for the radio turns off.
so i have to quickly place the car in neutral, turn the engine off, and then start it while the car is moving.
what could be the cause?
even if i have just replaced the alternator, it happened again just today while i was driving in edsa. the electrician told me it was a bad IC from the old alternator so i replaced it with a higher ampere.
need your help tsikot masters!
April 11th, 2014 09:05 AM #2
Hmm.. dami mo na rin pala napagawa. Anyway start tayo basics ulit for isolation lang
The way i see it based lang sa description mo its possible na electrical issue or fuel related problem yan. Try mo muna the following
1) Check the high tension wires baka may isa dyan may tama na. A tester will do ang replace all na kung hindi pa napapalitan
2) Double check the distributor cap baka pud pud na
3) Palagyan mo na ng grounding kit kahit i DIY mo na. I highly recommend you have this done
4) Check the fuel filter baka madumi na
5) Do you use an air filter for the carb? Kapag wala that will cause na pwede magbara sa passages yung dumi. Kung meron naman and you already used the car for 20,000 + KMS then its due for replacement na
6) When was the last time nagpalinis ka ng gas tank? This is optional naman kung wala ka napapansin na nakargahan ka ng may halong tubig
After doing this and hindi pa rin ok lets see kung ano pa pwede gawin later
April 11th, 2014 09:15 AM #3
Nagyari sa aking truck yan. Biglang mamamatay while running. Pag pinaandar, aandar ulit. Ang pagkakaiba lang ay diesel yung aking truck.
Pinatingnan sa casa, di nila naayos. Pinadala ko sa trusted na mekaniko, hinigpitan lang ang fuel filter. Ayon, good na.
- Oct 2012
- 142
April 11th, 2014 02:54 PM #4
If I may add a few points aside from what has been suggested,
Check your spark plug condition if the fuel is burned properly. If you can rewire the fan to it's original thermostat sensor controlled connection it would be better in my opinion. Are you experiencing slightly elevated engine temperature? They wired the fan directly to the battery so it can help your engine cooling system. However, doing this will shorten the life of the fan itself and besides if there really is a problem with the engine cooling system and air-con then these should be restored to their near original operating condition not with odd fixes. Check the current load in the alternator whenever the Aircon compressor kicks in. If you notice a significant change in reading then I suggest you also check the compressor winding. This may also have something to do with the shutting down problem compounded by the permanent fan load being installed "rekta". Sometimes the compressor is nearing it's end and the pistons inside are already misaligned and becomes a burden load for the engine and alternator. Just my two cents.
April 11th, 2014 03:01 PM #5
habang tumatakbo and namatay engine and other electrical system, try mo ikadyot ang clutch, pag hindi umandar malamang ignition switch ang problema mo.
- 54,207
April 11th, 2014 05:48 PM #6everything dies except the engine...
i experienced this twice or thrice over 14 years in my old sentra. after a few seconds, everything comes back to life.. parang minulto... very scary because they happened at night, and i couldn't see where i was going..
to this day, i do not know what happened..
April 11th, 2014 06:00 PM #7
nangyari sa akin yan sa NLEX cruising 100kph...between meyc exit and valenzuela nasa fast lane ako na biglang namatay lahat. Automatic ang dala ko mga 5-10sec biglang nabuhay ulit.
happen to me twice. Dinala ko sa casa wala silang nakita.
- Nov 2008
- 641
April 11th, 2014 07:01 PM #8Last edited by jvnj; April 11th, 2014 at 07:18 PM. Reason: insufficient info
- Jun 2011
- 91
April 11th, 2014 11:45 PM #9Nangyari na rin yan sa akin. Sa Exalta ko, ini-scan, walang nakita. Basa ako ng manual sa section ng undetected ng scan is Fuel Pump at madami pang iba. Linis ako ng TB, IACV, Fuel Tank, Change Fuel filter, change fuel pump and change Idle Screw. Nung natapos, hindi ko na na-experience yung bigla na lang mamatay yung kotse na walang ka-warning warning.
April 12th, 2014 08:28 AM #10
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
