Results 1 to 10 of 34
June 18th, 2004 01:35 AM #1
Being 1.6-liter engines, do these have the same maximum attainable power when modified?
In their construction, how does the 4A-GE 20V differ from the 4A-FE such that it produces around 50 hp more.
Lastly, in improving performance, is it really better to swap to the stronger engine rather than continuous modification of the standard?
June 18th, 2004 07:24 PM #2
The 4AGE has a wider angled cams, that alone makes the G model intrinsically more powerful than the F model.
For me its better to just change the whole engine. Iba pa rin ang reliability stock. I mean, rather than going through all the mods with the F engine.
June 19th, 2004 02:29 AM #3
No, I plan pa rin to modify the 4A-GE in case I will have it swapped.
Where I'm getting at here is that will the maximum attainable power of both engines be the same, or will the 4A-GE still be stronger.
June 19th, 2004 10:30 AM #4
4AGE is still stronger.
IF you do plan to do forced induction work, you might want to check out the 4AGZE (supercharged) version.
- May 2004
- 128
June 19th, 2004 11:16 AM #54age mas malakas.. get the black top.. tulad nitoo.. all motor na yan...!!! ÜÜ ***y nung makina noh..hehe
June 19th, 2004 11:32 AM #6
Grabe kamahal yung blacktop pag manual. Pero kung sa kalye lang natin ok na kahit stock. Kung plano mo mag-heavy mods lalo na for race, sa regular 16V ka na lang. Marami pang parts and you can easily surpass the blacktop's 160/165hp. I think may nag mod ng redtop over 200hp na.
Dami sa www.club4ag.com na info.
June 19th, 2004 11:33 AM #7
get the 4age. you can go turbo with the readily available bolt on turbochargers.
June 19th, 2004 02:45 PM #8
curious, which is better to turbocharge for both more HP & reliability?
4AGE 16v
4AGE 20v silver
4AGZE (piggy back turbo or remove supercharger and add big turbo)
(di pwede blacktop, mahal na kasi eh)
Just curious lang ako...
June 19th, 2004 03:12 PM #9
Question ko rin bakit mas marami ang nagsasabi na mas maganda daw ang 4AGZE na engine kaysa sa 4AGE?
Because pinoy mentality. Not surprising.
