Page 1 of 2 12 LastLast
Results 1 to 10 of 16
    May 2005
    Hello!
    It's been a long time since I last visited and posted in tsikot.
    Anyway, I hope I can get help with an intermittent Hill Start Assist Not Available warning in my wildtrak.
    It would occur either at startup or during driving already. I would stop, turn engine off and on again and it would go away.
    Sometimes it's the Check Park Aid warning and the ABS warning would also light up.
    and same solution.
    Odo reading is 18k kms only.
    I called Ford Alabang and they told me to bring it to them for diagnosis which will take 2-3 days and would cost 4.3k pesos just for the checkup.
    I searched here and in the ford sections but did not come across a post related to this. Hope I'm not wrong on this.
    Please advise.
    Nov 2019
    Quote Originally Posted by jrln View Post
    Hello!
    and same solution.
    Please advise.
    Try po muna pa scan po, warranty paba unit nyo?
    Mura lang scanning sa labas, at least makatipid kayo kaysa dalhin nyo sa CASA.
    Hindi naman ma void warranty if scanning lang ginagawa sa labas ng CASA.
    Also, baka may ngatngat ng daga isa sa mga wiring dyan.
    For sure, may error dapat na lalabas sa scan if natamaan wiring ng mga alaga nyo.
    May 2005
    Quote Originally Posted by carxynogen View Post
    Thanks for the response.
    Napa scan ko na po sa labas dati - 4 or 5 months ago. Naclear lang yung error pero nagrerecur pa rin from time to time pero not all the time.
    Will try to look at wiring as you advised.
    Again, thanks.
    Jun 2011
    Hhmmm... kung under warranty, baka puwede charge sa warranty ang checkup?
    May 2005
    Quote Originally Posted by bxr monkey View Post
    2019 wildtrak po kaya out of warranty na.
    Jun 2011
    Ay oo nga, 5 years na pala. Ang baba ng mileage.
    Maganda nga ipa scan sa labas at pahanap ang break sa wiring malapit sa ABS module at wheel brakes. Recommnded dati dito Speedyfix or Speedlab.
    Ok din sa Hazardboy Las Pinas.
    Log into Facebook | Facebook
    May 2005
    Saan po yung Hazardboy Las Pinas? In google maps, there's one in Paranaque near Merville but says permanently closed.
    Will try to go to Customers Cradle Las Pinas this week for scanning and to lift the car so we can inspect possible wiring damage.
    Thanks po ulit sa sagot.
    Jan 2009
    Find a place that will actually do proper diagnosing instead of just clearing the codes.
    There are mechanics with a scanner that can point you in the general direction of the fault.
    But there are mechanics with a scanner and knows how to actually find the actual fault(s) and fix it.
    Jun 2011
    Alam ko temporary sila lumipat sa DetailPlus.
    From Googlemaps.
    Block 6, Lot 5 J.Tionquiao, Las Piñas, 1740 Metro Manila
    Maganda mag message muna sa Hazardboy/Detailplus para ma confirm address.
    Pa quote na din ng scanning and repair labor, if wiring lang or sensor replacement.
    Ito ang picture ng gate na same sa na send ng relative namin na customer nila. Maayos daw gawa nila.
    Facebook? ??? | Facebook
    May 2005
    Yes, that's what I'm looking for with the help of this forum.
    At any rate, I brought the car to Customers Cradle Las Pinas yesterday.
    They said that it's better to scan it if the error is always there so they did not recommend to scan.
    Next, we lifted the car to inspect the wirings. Everything was in good order. No rat or cat bites whatsoever. The lines looked good all throughout.
    The good thing is the error has not reappeared after 4 drives since it was last encountered. Hopefully, it does not come back anymore.
2019 ranger wildtrak hillstart assist not available
